Hi
I have a remote House with Homematic IP and I try to integrate the remote access point into my local home automation. is this possible?
many thanks for any support
Kind Regards
Alex
If you make a way VPN connection between the two networks then you should have no issues adding the remote AP to HA manually.
thanks for your quick reply. as I understand a direct connection is necessary. correct?
is this only necessary for the connection or also for operation?
You could make a portforward of the ports Homemaric IP uses, but you would have to restrict access to those port like only allow the connection from a specific IP or such.
If you have the connection for the ports, then all operations are available.
ok, thanks.
I try
have a nice day
