HomematicIP Climate entity has no hvac_action
Hi, since the valve state is in the api for the FALMOT. The „hvac_action“ and the valve state ( or pulse_width_modulation) could be in the climate entity.
This would be with the given HMIP functions perfect.
To set a heat circulation pump to right power ( or at least on off).
Other benefits you see in the climate graph chart, when the heating heats and when it is not heating.
Regarding on this there is also a climate group possible, because this one relies on the „hvac_action“.
Could this be achieved to get both values in to the entity?
Thx!
