is it possible to implement the control of the homematicIP Cloud shutter actuator to HA?
According to the Github page of the used API, it already supports both components (HMIP-FROLL & HMIP-BROLL).
The best would be to contact Mattias Welponer (mxworm) who created the HmIP Cloud Component to add the latest REST-API version with HmIP-FROLL and HmIP-BROLL.
I don’t own a FROLL or BROLL device, can you test?
https://github.com/mxworm/home-assistant/tree/homematicip_cloud-cover_broll_froll
Thanks Mattias
Hi Matthias,
I’d would like to test your integration - as I have multiple HMIP-Broll actors.
What shall I do?
Hello Matthias,
please give us a short description how the tester need to implement “nightly” preversion.
Regards
Thomas
I can test it too.
I’m using 10 HMIP-BROLL and other components.
Is it possible to get access to a nighly Version?
Best regards
Overview - which devices are documented right now in the REST-API and which are working in the Home Assistant Component for Homematic IP:
https://dl.dropboxusercontent.com/s/y5m0xpn1dfx9eys/REST-API.vs.HASS.xlsx
