No luck. Ill keep working on it
can you post your automation that is not working. Maybe I can see something.
I have 12 automations that work with my 1 WD200 and 1 WD300.
Also check your Zwave Device Configuration - attached in my WD200+
That looks very interesting and I am going to look at your example. I got my leds green or red depending on rooms being ON or OFF. The only thing I have not worked out yet is to a specific led to blink. Maybe your example helps me (later today).
How do I get to :
I went into the device configuration of the HS-200 but. unlike in your images, it does not give me the option to change the value of any parameter.
it looks like your in the right place, but mine is different,
HomeSeer Firmware: 5.14
on the left side of HA click on “Settings” then “Devices & Services” then “devices” under Z-Wave JS, then the HomeSeer device you want, then “Configure”
