Packet.log is empty. 0 bytes…
Here’s as much grep evohome as it will let me post. If you need more I will Pm you a link:
2020-10-15 02:22:23 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for evohome_cc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-10-15 02:22:25 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'home_connect', 'display', 'conversation', 'alarm_control_panel', 'updater', 'input_select', 'openweathermap', 'life360', 'dreamscreen', 'proximity', 'rest_command', 'logbook', 'evohome', 'evohome_cc', 'hacs', 'automation', 'input_boolean', 'camera', 'device_tracker', 'notify', 'shell_command', 'speedtestdotnet', 'sensor', 'discovery', 'python_script', 'smartthinq_sensors', 'bmw_connected_drive', 'map', 'coronavirus', 'zwave', 'ios', 'system_health', 'cast', 'browser_mod', 'ipp', 'input_text', 'airvisual', 'nest', 'withings', 'sun', 'alert', 'mqtt', 'input_number', 'script', 'alexa_media', 'remote', 'synology_dsm', 'harmony', 'tag', 'group', 'persistent_notification', 'variable', 'binary_sensor', 'google', 'zone', 'history', 'weather', 'light', 'zeroconf', 'influxdb', 'mobile_app', 'fan', 'timer', 'media_player'}
2020-10-15 02:22:25 INFO (MainThread) [homeassistant.setup] Setting up evohome_cc
2020-10-15 02:22:26 DEBUG (SyncWorker_13) [homeassistant.util.json] JSON file not found: /config/.storage/evohome_cc
2020-10-15 02:22:26 DEBUG (MainThread) [custom_components.evohome_cc] Store = {}, Config = OrderedDict([('scan_interval', datetime.timedelta(seconds=60)), ('serial_port', '/dev/ttyUSB0'), ('packet_log', '/share/packet.log'), ('schema', OrderedDict([('controller', '01:158182')])), ('max_zones', 12)])
2020-10-15 02:22:26 INFO (MainThread) [homeassistant.setup] Setup of domain evohome_cc took 0.5 seconds
2020-10-15 02:22:26 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=evohome_cc>
2020-10-15 02:22:26 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en, state: onboarding, conversation, alarm_control_panel, light.template, system_log, config, binary_sensor.mqtt, recorder, person, binary_sensor.cloud, hassio, device_automation, alarm_control_panel.mqtt, sun, stt, mqtt, rest_command, websocket_api, frontend, cloud, lovelace, auth, binary_sensor.template, logbook, api, evohome_cc, alexa, tag, persistent_notification, group, binary_sensor, shell_command, history, media_player, webhook, light, map, http, notify.group, homeassistant, image, logger, search, system_health
2020-10-15 02:22:26 DEBUG (SyncWorker_9) [homeassistant.util.json] JSON file not found: /config/custom_components/evohome_cc/translations/en.json
2020-10-15 02:22:27 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en, state: onboarding, conversation, alarm_control_panel, light.template, system_log, config, binary_sensor.mqtt, input_select, recorder, person, input_text, binary_sensor.cloud, hassio, device_automation, alarm_control_panel.mqtt, sun, stt, mqtt, rest_command, alert, input_number, websocket_api, frontend, cloud, lovelace, auth, binary_sensor.template, logbook, api, media_player.itunes, evohome_cc, alexa, automation, input_boolean, tag, persistent_notification, group, binary_sensor, shell_command, history, media_player, webhook, notify, light, variable, zeroconf, map, http, zone, notify.group, homeassistant, timer, image, logger, search, system_health
2020-10-15 02:22:27 DEBUG (SyncWorker_17) [homeassistant.util.json] JSON file not found: /config/custom_components/evohome_cc/translations/en.json
2020-10-15 02:22:27 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en, state: onboarding, conversation, alarm_control_panel, light.template, system_log, config, binary_sensor.mqtt, input_select, recorder, person, input_text, ios, binary_sensor.cloud, hassio, device_automation, alarm_control_panel.mqtt, proximity, sun, notify.ios, stt, mqtt, rest_command, alert, input_number, websocket_api, frontend, cloud, lovelace, auth, binary_sensor.template, script, logbook, api, media_player.itunes, evohome_cc, alexa, automation, input_boolean, tag, persistent_notification, group, binary_sensor, shell_command, history, media_player, webhook, notify, light, variable, zeroconf, device_tracker, map, http, zone, notify.group, homeassistant, timer, image, logger, search, system_health
2020-10-15 02:22:27 DEBUG (SyncWorker_2) [homeassistant.util.json] JSON file not found: /config/custom_components/evohome_cc/translations/en.json
2020-10-15 02:22:27 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en, title: conversation, onboarding, alarm_control_panel, system_log, config, input_select, input_text, recorder, person, hassio, device_automation, proximity, sun, stt, mqtt, rest_command, alert, input_number, websocket_api, frontend, cloud, lovelace, auth, system_health, script, logbook, api, evohome_cc, alexa, automation, input_boolean, tag, persistent_notification, group, binary_sensor, shell_command, history, notify, webhook, variable, light, zeroconf, device_tracker, search, map, http, zone, homeassistant, timer, image, logger, ios, media_player
2020-10-15 02:22:27 DEBUG (SyncWorker_9) [homeassistant.util.json] JSON file not found: /config/custom_components/evohome_cc/translations/en.json
2020-10-15 02:22:31 INFO (MainThread) [homeassistant.setup] Setting up evohome
2020-10-15 02:22:31 DEBUG (MainThread) [evohomeasync2] Debug mode is not explicitly enabled (but may be enabled elsewhere).
2020-10-15 02:22:32 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en, state: display, conversation, light.template, alarm_control_panel, updater, system_log, input_select, openweathermap, recorder, person, life360, hassio, device_automation, dreamscreen, proximity, stt, rest_command, cloud, auth, binary_sensor.template, logbook, evohome_cc, automation, input_boolean, notify, shell_command, device_tracker, map, http, notify.group, logger, ios, binary_sensor.cloud, search, system_health, onboarding, config, binary_sensor.mqtt, input_text, display.fully_kiosk, binary_sensor.updater, alarm_control_panel.mqtt, sun, notify.ios, alert, mqtt, input_number, websocket_api, frontend, lovelace, script, api, media_player.itunes, alexa, tag, persistent_notification, group, binary_sensor, variable, history, zone, webhook, light, zeroconf, homeassistant, timer, image, media_player
2020-10-15 02:22:32 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /config/custom_components/evohome_cc/translations/en.json
2020-10-15 02:22:32 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en, title: display, onboarding, conversation, alarm_control_panel, updater, system_log, config, input_select, input_text, recorder, person, openweathermap, life360, hassio, device_automation, dreamscreen, proximity, sun, stt, mqtt, rest_command, alert, input_number, websocket_api, frontend, cloud, lovelace, auth, system_health, script, logbook, api, evohome_cc, alexa, automation, input_boolean, tag, persistent_notification, group, binary_sensor, shell_command, history, notify, webhook, variable, light, zeroconf, device_tracker, search, map, http, zone, homeassistant, timer, image, logger, ios, media_player
2020-10-15 02:22:32 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /config/custom_components/evohome_cc/translations/en.json
2020-10-15 02:22:32 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en, state: display, conversation, light.template, alarm_control_panel, updater, system_log, input_select, openweathermap, person, recorder, life360, hassio, device_automation, dreamscreen, proximity, lock, climate.zwave, stt, rest_command, switch, cloud, auth, binary_sensor.template, logbook, binary_sensor.bmw_connected_drive, climate, evohome_cc, automation, input_boolean, notify, device_tracker, shell_command, speedtestdotnet, python_script, bmw_connected_drive, map, light.zwave, http, coronavirus, zwave, notify.group, logger, ios, system_health, binary_sensor.cloud, search, onboarding, config, binary_sensor.mqtt, input_text, display.fully_kiosk, binary_sensor.updater, lock.zwave, lock.bmw_connected_drive, alarm_control_panel.mqtt, sun, notify.ios, alert, mqtt, cover, input_number, websocket_api, switch.zwave, frontend, lovelace, script, notify.bmw_connected_drive, remote, api, media_player.itunes, alexa, tag, persistent_notification, group, binary_sensor, variable, zone, history, webhook, light, zeroconf, cover.zwave, homeassistant, timer, image, media_player, binary_sensor.zwave
2020-10-15 02:22:32 DEBUG (SyncWorker_16) [homeassistant.util.json] JSON file not found: /config/custom_components/evohome_cc/translations/en.json
2020-10-15 02:22:33 DEBUG (MainThread) [homeassistant.components.evohome] Config = {'locationInfo': {'timeZone': {'timeZoneId': 'CentralEuropeStandardTime', 'displayName': '(UTC+01:00) Belgrade, Bratislava, Budapest, Ljubljana, Prague', 'offsetMinutes': 60, 'currentOffsetMinutes': 120, 'supportsDaylightSaving': True}}, 'gateways': [{'temperatureControlSystems': [{'systemId': '4187037', 'modelType': 'EvoTouch', 'zones': [{'zoneId': '4187036', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Living Room', 'zoneType': 'RadiatorZone'}, {'zoneId': '4217766', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Dining Room', 'zoneType': 'RadiatorZone'}, {'zoneId': '4217767', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Entrance', 'zoneType': 'RadiatorZone'}, {'zoneId': '4217768', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Laundry room', 'zoneType': 'RadiatorZone'}, {'zoneId': '4217769', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': "Sebastian's Room", 'zoneType': 'RadiatorZone'}, {'zoneId': '4217770', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': "Sophie's Room", 'zoneType': 'RadiatorZone'}, {'zoneId': '4217771', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Guest Bedroom', 'zoneType': 'RadiatorZone'}, {'zoneId': '4217772', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Master Closet', 'zoneType': 'RadiatorZone'}, {'zoneId': '4217773', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Master Bedroom', 'zoneType': 'RadiatorZone'}, {'zoneId': '4217774', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Garage', 'zoneType': 'RadiatorZone'}, {'zoneId': '4217775', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Office & Library', 'zoneType': 'RadiatorZone'}, {'zoneId': '4217776', 'modelType': 'HeatingZone', 'setpointCapabilities': {'maxHeatSetpoint': 25.0, 'minHeatSetpoint': 5.0, 'valueResolution': 0.5, 'canControlHeat': True, 'canControlCool': False, 'allowedSetpointModes': ['PermanentOverride', 'FollowSchedule', 'TemporaryOverride'], 'maxDuration': '1.00:00:00', 'timingResolution': '00:10:00'}, 'scheduleCapabilities': {'maxSwitchpointsPerDay': 6, 'minSwitchpointsPerDay': 1, 'timingResolution': '00:10:00', 'setpointValueResolution': 0.5}, 'name': 'Master Bath', 'zoneType': 'ZoneTemperatureControl'}], 'allowedSystemModes': [{'systemMode': 'Auto', 'canBePermanent': True, 'canBeTemporary': False}, {'systemMode': 'AutoWithEco', 'canBePermanent': True, 'canBeTemporary': True, 'maxDuration': '1.00:00:00', 'timingResolution': '01:00:00', 'timingMode': 'Duration'}, {'systemMode': 'AutoWithReset', 'canBePermanent': True, 'canBeTemporary': False}, {'systemMode': 'Away', 'canBePermanent': True, 'canBeTemporary': True, 'maxDuration': '99.00:00:00', 'timingResolution': '1.00:00:00', 'timingMode': 'Period'}, {'systemMode': 'DayOff', 'canBePermanent': True, 'canBeTemporary': True, 'maxDuration': '99.00:00:00', 'timingResolution': '1.00:00:00', 'timingMode': 'Period'}, {'systemMode': 'HeatingOff', 'canBePermanent': True, 'canBeTemporary': False}, {'systemMode': 'Custom', 'canBePermanent': True, 'canBeTemporary': True, 'maxDuration': '99.00:00:00', 'timingResolution': '1.00:00:00', 'timingMode': 'Period'}]}]}]}
2020-10-15 02:22:33 DEBUG (MainThread) [evohomeasync] Debug mode is not explicitly enabled (but may be enabled elsewhere).
2020-10-15 02:22:33 DEBUG (SyncWorker_15) [homeassistant.helpers.storage] Writing data for evohome
2020-10-15 02:22:33 DEBUG (MainThread) [homeassistant.components.evohome] Status = {'locationId': '3184115', 'gateways': [{'gatewayId': '2937956', 'temperatureControlSystems': [{'systemId': '4187037', 'zones': [{'zoneId': '4187036', 'temperatureStatus': {'temperature': 23.5, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 21.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Living Room'}, {'zoneId': '4217766', 'temperatureStatus': {'temperature': 20.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 18.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Dining Room'}, {'zoneId': '4217767', 'temperatureStatus': {'temperature': 19.5, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 19.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Entrance'}, {'zoneId': '4217768', 'temperatureStatus': {'temperature': 22.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 22.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Laundry room'}, {'zoneId': '4217769', 'temperatureStatus': {'temperature': 22.5, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 23.0, 'setpointMode': 'FollowSchedule'}, 'name': "Sebastian's Room"}, {'zoneId': '4217770', 'temperatureStatus': {'temperature': 21.5, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 21.5, 'setpointMode': 'FollowSchedule'}, 'name': "Sophie's Room"}, {'zoneId': '4217771', 'temperatureStatus': {'temperature': 20.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 18.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Guest Bedroom'}, {'zoneId': '4217772', 'temperatureStatus': {'temperature': 22.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 20.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Master Closet'}, {'zoneId': '4217773', 'temperatureStatus': {'temperature': 22.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 22.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Master Bedroom'}, {'zoneId': '4217774', 'temperatureStatus': {'temperature': 18.5, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 18.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Garage'}, {'zoneId': '4217775', 'temperatureStatus': {'temperature': 21.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 18.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Office & Library'}, {'zoneId': '4217776', 'temperatureStatus': {'temperature': 22.5, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 21.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Master Bath'}], 'activeFaults': [], 'systemModeStatus': {'mode': 'DayOff', 'isPermanent': True}}], 'activeFaults': []}]}
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome] Temperatures = {'4217766': 20.3, '4217767': 19.61, '4217774': 18.84, '4217771': 20.06, '4217768': 21.72, '4187036': 23.73, '4217776': 22.86, '4217773': 21.76, '4217772': 22.15, '4217775': 21.22, '4217769': 22.26, '4217770': 21.69}
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=evohome, service=refresh_system>
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=evohome, service=reset_system>
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=evohome, service=set_system_mode>
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=evohome, service=clear_zone_override>
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=evohome, service=set_zone_override>
2020-10-15 02:22:34 INFO (MainThread) [homeassistant.setup] Setup of domain evohome took 3.2 seconds
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=load_platform.climate, platform=evohome, discovered=>
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=evohome>
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en, state: display, conversation, light.template, alarm_control_panel, updater, binary_sensor.withings, system_log, input_select, openweathermap, person, recorder, life360, hassio, device_automation, dreamscreen, proximity, lock, climate.zwave, stt, rest_command, switch, cloud, auth, binary_sensor.template, logbook, binary_sensor.bmw_connected_drive, climate, evohome, evohome_cc, automation, input_boolean, notify, device_tracker, shell_command, speedtestdotnet, python_script, bmw_connected_drive, climate.nest, map, light.zwave, http, coronavirus, zwave, notify.group, binary_sensor.nest, logger, ios, system_health, binary_sensor.cloud, search, onboarding, ipp, config, binary_sensor.mqtt, input_text, air_quality.airvisual, display.fully_kiosk, binary_sensor.updater, lock.zwave, lock.bmw_connected_drive, alarm_control_panel.mqtt, airvisual, nest, withings, sun, notify.ios, alert, mqtt, cover, input_number, websocket_api, switch.zwave, frontend, lovelace, script, notify.bmw_connected_drive, remote, api, media_player.itunes, alexa, tag, persistent_notification, group, binary_sensor, variable, zone, history, webhook, light, zeroconf, air_quality, cover.zwave, homeassistant, timer, image, media_player, binary_sensor.zwave
2020-10-15 02:22:34 INFO (MainThread) [homeassistant.components.climate] Setting up climate.evohome
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Found the Location/Controller (EvoTouch), id=4187037, name=Straus House (location_idx=0)
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4187036, name=Living Room
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217766, name=Dining Room
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217767, name=Entrance
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217768, name=Laundry room
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217769, name=Sebastian's Room
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217770, name=Sophie's Room
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217771, name=Guest Bedroom
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217772, name=Master Closet
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217773, name=Master Bedroom
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217774, name=Garage
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: RadiatorZone (HeatingZone), id=4217775, name=Office & Library
2020-10-15 02:22:34 DEBUG (MainThread) [homeassistant.components.evohome.climate] Adding: ZoneTemperatureControl (HeatingZone), id=4217776, name=Master Bath
