Should be OK now - please test.
It seems indeed to work now.
There was a strange occurrence where the eco -> auto resulted in away. Donāt know if it was a single event or reproduceable, still trying to capture all the steps that where taken.
Just send your packet log - may have been a corrupt packet.
Packet log shared through message
just upgraded to the latest version:
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/evohome_cc/climate.py:383
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 19:40:49 (1 occurrences)
Last logged: 19:40:49
[139778802225792] 'EvoController' object has no attribute 'svc_set_zone_mode'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 141, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1488, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1523, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 642, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 681, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 679, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 446, in async_set_preset_mode
await self.hass.async_add_executor_job(self.set_preset_mode, preset_mode)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/evohome_cc/climate.py", line 383, in set_preset_mode
self.svc_set_zone_mode(HA_PRESET_TO_TCS.get(preset_mode, SystemMode.AWAY))
AttributeError: 'EvoController' object has no attribute 'svc_set_zone_mode'
Iām assume this issue I have is related to this:
I have identified, fixed & pushed a commit to fix this bug
The hint is in the docstring:
def set_preset_mode(self, preset_mode: Optional[str]) -> None:
"""Set the preset mode; if None, then revert to 'Auto' mode."""
self.svc_set_system_mode(HA_PRESET_TO_TCS.get(preset_mode, SystemMode.AWAY))
A fix has been pushed.
Just tested it going from ECO -> None(Auto) results in āDay Offā, some mapping going wrong?
This mapping is complex & you see I havenāt tested it a lot!
( I have people who do that for me )
Here I see a mapping issue:
@phdelodder Thatās a nice spot - Iām not sure how long that would have taken me to find!
Itās the following line that reveal the bug:
SYSTEM_MODE_LOOKUP = {v: k for k, v in SYSTEM_MODE_MAP.items()}
Which maps SystemMode.AUTO
to SYS_MODE_DAY_OFF_ECO
instead of SYS_MODE_AUTO
For me with the latest commit b119afa itās running fine. All the functions/services I use are working like intended.
The same here! itās running fine!
I am afraid Iāll be refactoring the mode/preset code, which may introduce new bugs (this is for code quality, with a view to becoming an official integration).
In addition, I will be adding all the native mode to the state attributes, e.g., for the controller:
{'system_mode': 'auto', 'until': None}
ā¦ so will be be able to do things like:
{% if state_attr('climate.my_home', 'status').system_mode.system_mode== "away" %}
The system is in Away mode
{% else %}
The system is not in Away mode
{% endif %}
ā¦ and, for zones (and similarly for DHW):
{'mode': 'follow_schedule', 'setpoint': 20.0}
I strongly recommend people use the native service calls to set System/Zone/DHW modes - the schema imposed by HA is a bit limiting - it has no concept of āFollowScheduleā, for example.
The option change schedule is not gonna be an option? Or do i donāt understand your message?
I am talking about something else.
Evohome Zones can be in any of three modes:
- follow_schedule
- permanent_override
- temporary_override (revert to follow_schedule after a while)
In addition there are other modes accessible to us via evohome_rf, mainly:
- advanced_override (revert to follow_schedule set next setpoint)
HA has several modes, including:
HVAC_AUTO
(follow_schedule) HVAC_HEAT
HA has no way of distinguishing between the 2/3 overrides (temp/perm/advance). So when you change temp on a zone via the HA UI, you clearly intend to move from a mode (it may be follow_schedule) to one of the 2/3 override modes, but which one?
Iāll give you another example;
HVAC_OFF
ā¦ which applies to the Controller (heat_off), but not the Zones.
Perhaps this is planned for somewhere further down the line, but some form of persistence or assumed state between restarts would be good.
Invariably my HA instance gets restarted at least once a day, for various updates, so itās rare that I ever have a complete āavailableā states for things like battery, open window, etc
I like the way it currently is, eg:
When changing a setpoint through HA UI it set it self to temp override, if I want it permanent Iāll change the preset to permanent. Additional if I want a specific duration I can use the evohome_cc.set_zone_mode
Hope it doesnāt change to much.
Can this modes info be added to the services.yaml for the call(s) that has the option available?
This is planned - it is a non-trivial problem.
