I am gonna try it!
I found the problem, somehow when i pulled out the nanocul for looking if i needed to reflash with old bootloader it switched over to my other usb device on usb1 for my smart eclictricity meter.
i saw it when i pulled the nanocul again and the messages keeped comming.
This is what I got:
I just post this some where else:
A deviceās location in the schema is tenuous, and the schema is what the controller believes to be true. Of course, your own ātruthā (e.g. a TRV is in a zone) is irrelevant to the controller (as many people see when they first start using evohome_rf). The controller uses the schema to maintain state, and evohome_rf hopes to construct the same schema as the controller for reasons that will become obvious soonā¦
Many devices, including the controller have a built-in temperature sensor, and evohome_rf eavesdrops the reporting of these (which are cast for the controllerās benefit), as it maintains the system state in a manner similar to the controller. Note the evohome controller doesnāt have to broadcast itās own temperature to itself and, sadly, doesnāt do so.
Now a zoneās temperature (as reported by the controller) is the temperature of the device tagged in the controllers schema as the sensor for that zone. There is no other plan, such as:
- no alternative sensor device should the first stop reporting temps for whatever reason
- no average of all the temps of all the sensors in that zone
evhome_rf uses discovery (i.e. it simply asks the controller) to get the schema - and thus to get teh device ID of each zoneās sensor. Unfortunately, the controller doesnāt tell you what zone it is the sensor for - that zone will simply be reported as having no sensor.
There are other issues too, but the main point is this - evohome_rf cannot guarantee it knows what zone the controller is a sensor for (from discovery), although it could in many circumstances be very confident of which (from eavesdropping - this feature is not enabled, presently).
TL;DR: The controller uses device data (e.g. sensor temperatures, actuator heat demands), resolved against an internal schema, to determine the system state (e.g. zone temperature).
Some of this data (e.g. the controllerās sensor temperature, each zoneās heat demand) is not able to be determined by evohome_rf without behaving as the controller does, by resolving these packets against the schema.
For anyone who hasnāt seen before: configuration.yaml: useful sensor templates
These will give access to sensors not available otherwise.
@scstraus You seem to be an expert on templating - have you done some templates for the native zone/controller modes from the Controller/Zone/DHW device_state_attributes
that you can share?
Then Iāll transcribe them to the evohome_cc wiki.
Unfortunately I havenāt gotten back to figuring out my Evohome RF issues since my new hass server refused to properly recognize my HGI-80. Iāve been meaning to try it again on my old server but never got around to setting it up again. I would be happy to help write the templates, though, but someone should test that they work before putting them in the docs. Could you point me to documentation about which attributes you want to extract to sensors?
Ah! You need a nanoCUL (or one of the newer HW uart version - TBA).
Iām still seeing a log of orphans after a day of running. Can I force these to a zone using schema: in configuration.yaml? e.g. this is the (bad) schema output from the log:
Schema =
{'controller': '01:201047',
'system':
{'heating_relay': '13:259021'},
'orphans': ['04:173125', '04:173127', '04:173131', '04:173146', '04:176841', '04:177708', '04:177711', '04:177712', '04:177713', '04:177718', '04:179866', '04:179981', '04:179993','04:179995'],
Does something like this work in configuration.yaml?:
schema:
controller: 01:201047
system:
heating_relay: 13:259021
zones:
00:
heating_type: radiator_valve
sensor: null
devices:
04:039325
04:039321
04:039319
04:039323
FYI, this is an extract from the packet log, where the zone is indicated, so not sure why its not getting picked up:
062 I --- 04:173131 --:------ 01:201047 3150 002 01C8
056 I --- 04:173125 --:------ 01:201047 3150 002 01C8
079 I --- 04:179981 --:------ 01:201047 3150 002 01C8
Itās not being picked up - I call this eavesdropping - because I have chosen for it not to be picked up.
Creating a schema by eavesdropping is not appropriate for evohome - but youāre hometronics, right?
I am about to add āprofileā functionality - evohome_rf will behave differently for chronotherm / evohome / sundial / hometronics / etc.
If youāre hometronics, would you be interested in testing this for me?
Hmm, no - main system is a full 12-zone evohome. Then Iām guessing the schema is picked up from the initial evohome_rf probe. Let me run client.py directly and see what happens with the missed orphansā¦
python client.py monitor -x "RQ 01:xxxxxx 1F09 00" -o packet.log
where 01:xxxxxx
is your controller ID.
Discovery finished after about 2 mins - in all that time, there should be may 3-6 retransmits max - send me the log file if things are tricky.
I now have a suspicion. I have a mixture of HR80 and HR92 TRVs. The controller appears to only report back the HR92s in the 000C zone actuator response. So zone with only HR80s come back empty (zones 1,2,3) and zone 0 which is a mixture of HR80/HR92 only reports the HR92s.
The HR80s were in the house when we moved in, which is why I stuck with evohome and completed the system with newer HR92s.
I remember vaguely that the HR80s do 1-way binding and the HR92s have 2-way? So not sure the controller actually stores the HR80 IDās, or maybe some other request would cause it spit it out
2021-03-20T19:21:20.344701
2021-03-20T19:21:20.886427 # evofw3 0.6.16
2021-03-20T19:21:20.921560 000 I --- 18:139815 63:262142 --:------ 7FFF 008 0176302E362E367F
2021-03-20T19:21:20.949766 000 RQ --- 18:139815 01:201047 --:------ 1F09 001 00
2021-03-20T19:21:20.963480 077 RP --- 01:201047 18:139815 --:------ 1F09 003 0006A4
2021-03-20T19:21:21.007221 000 RQ --- 18:139815 01:201047 --:------ 0016 001 00
2021-03-20T19:21:21.020470 076 RP --- 01:201047 18:139815 --:------ 0016 002 0010
2021-03-20T19:21:21.062471 000 RQ --- 18:139815 01:201047 --:------ 10E0 001 00
2021-03-20T19:21:21.316323 072 I --- 04:177712 --:------ 01:201047 1060 003 00FF01
2021-03-20T19:21:21.327307 073 I --- 04:177712 --:------ 04:177712 1060 003 00FF01
2021-03-20T19:21:21.865275 000 RQ --- 18:139815 01:201047 --:------ 1FC9 001 00
2021-03-20T19:21:21.887307 078 RP --- 01:201047 18:139815 --:------ 1FC9 012 0010E0071157001FC9071157
2021-03-20T19:21:21.921205 000 RQ --- 18:139815 01:201047 --:------ 000C 002 000D
2021-03-20T19:21:21.937728 077 RP --- 01:201047 18:139815 --:------ 000C 006 000D7FFFFFFF
2021-03-20T19:21:22.038337 000 RQ --- 18:139815 01:201047 --:------ 000C 002 000F
2021-03-20T19:21:22.054315 078 RP --- 01:201047 18:139815 --:------ 000C 006 000F0037F3CD
2021-03-20T19:21:22.096451 000 RQ --- 18:139815 01:201047 --:------ 1100 001 FC
2021-03-20T19:21:22.114361 078 RP --- 01:201047 18:139815 --:------ 1100 008 FC301400007FFF01
2021-03-20T19:21:22.154237 000 RQ --- 18:139815 01:201047 --:------ 313F 001 00
2021-03-20T19:21:22.172974 077 RP --- 01:201047 18:139815 --:------ 313F 009 00FC1D16B3140307E5
2021-03-20T19:21:22.210239 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0008
2021-03-20T19:21:22.225165 077 RP --- 01:201047 18:139815 --:------ 0005 004 0008FF0F
2021-03-20T19:21:22.284278 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0009
2021-03-20T19:21:22.298292 077 RP --- 01:201047 18:139815 --:------ 0005 004 00090000
2021-03-20T19:21:22.344497 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000A
2021-03-20T19:21:22.358793 077 RP --- 01:201047 18:139815 --:------ 0005 004 000A0000
2021-03-20T19:21:22.411100 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000B
2021-03-20T19:21:22.428367 076 RP --- 01:201047 18:139815 --:------ 0005 004 000B0000
2021-03-20T19:21:22.473276 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0011
2021-03-20T19:21:22.488389 076 RP --- 01:201047 18:139815 --:------ 0005 004 00110000
2021-03-20T19:21:22.534205 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0000
2021-03-20T19:21:22.549613 077 RP --- 01:201047 18:139815 --:------ 0005 004 0000FF0F
2021-03-20T19:21:22.592773 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0010
2021-03-20T19:21:22.610486 077 RP --- 01:201047 18:139815 --:------ 0005 004 00100000
2021-03-20T19:21:22.652388 000 RQ --- 18:139815 01:201047 --:------ 0006 001 00
2021-03-20T19:21:22.666157 077 RP --- 01:201047 18:139815 --:------ 0006 004 00050158
2021-03-20T19:21:22.711644 000 RQ --- 18:139815 13:259021 --:------ 1100 001 00
2021-03-20T19:21:22.726585 087 RP --- 13:259021 18:139815 --:------ 1100 008 00301400007FFF01
2021-03-20T19:21:22.771837 000 RQ --- 18:139815 13:259021 --:------ 0008 001 00
2021-03-20T19:21:22.782409 087 RP --- 13:259021 18:139815 --:------ 0008 002 007E
2021-03-20T19:21:22.829622 000 RQ --- 18:139815 13:259021 --:------ 3EF1 001 00
2021-03-20T19:21:23.358585 000 RQ --- 18:139815 13:259021 --:------ 3EF1 001 00
2021-03-20T19:21:24.309360 095 I --- 04:177718 --:------ 01:201047 3150 002 0088
2021-03-20T19:21:24.810903 073 I --- 04:179866 --:------ 01:201047 3150 002 0362
2021-03-20T19:21:25.310778 076 I --- 04:173127 --:------ 01:201047 3150 002 0240
2021-03-20T19:21:26.358115 000 RQ --- 18:139815 13:259021 --:------ 3EF1 001 00
2021-03-20T19:21:26.372446 086 RP --- 13:259021 18:139815 --:------ 3EF1 007 0000170017C8FF
2021-03-20T19:21:26.413147 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0000
2021-03-20T19:21:26.453136 076 RP --- 01:201047 18:139815 --:------ 000C 036 00000010999D00000010999900000010999700000010999B00000010D25B00000010D263
2021-03-20T19:21:26.497618 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0100
2021-03-20T19:21:26.511295 076 RP --- 01:201047 18:139815 --:------ 30C9 003 01080E
2021-03-20T19:21:26.557338 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0200
2021-03-20T19:21:26.571966 077 RP --- 01:201047 18:139815 --:------ 000A 006 021003E80960
2021-03-20T19:21:26.618325 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0100
2021-03-20T19:21:26.640373 076 RP --- 01:201047 18:139815 --:------ 2349 013 01083404FFFFFF1E15140307E5
2021-03-20T19:21:26.675957 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0200
2021-03-20T19:21:26.703535 078 RP --- 01:201047 18:139815 --:------ 0004 022 02004D61737465722042617468000000000000000000
2021-03-20T19:21:26.736607 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0200
2021-03-20T19:21:26.751821 076 RP --- 01:201047 18:139815 --:------ 12B0 003 020000
2021-03-20T19:21:26.793845 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0304
2021-03-20T19:21:26.811346 077 RP --- 01:201047 18:139815 --:------ 000C 006 03040058704D
2021-03-20T19:21:26.851434 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0300
2021-03-20T19:21:26.867106 076 RP --- 01:201047 18:139815 --:------ 000A 006 031103E80960
2021-03-20T19:21:26.905894 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0300
2021-03-20T19:21:26.921730 077 RP --- 01:201047 18:139815 --:------ 2349 007 03083400FFFFFF
2021-03-20T19:21:26.965964 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0308
2021-03-20T19:21:26.982763 076 RP --- 01:201047 18:139815 --:------ 000C 006 03087FFFFFFF
2021-03-20T19:21:27.022654 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0000
2021-03-20T19:21:27.563648 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0000
2021-03-20T19:21:27.581230 076 RP --- 01:201047 18:139815 --:------ 000A 006 001203E80960
2021-03-20T19:21:27.619086 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0404
2021-03-20T19:21:27.635983 077 RP --- 01:201047 18:139815 --:------ 000C 006 040400586FF9
2021-03-20T19:21:27.674195 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0400
2021-03-20T19:21:27.689087 076 RP --- 01:201047 18:139815 --:------ 12B0 003 040000
2021-03-20T19:21:27.733349 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0100
2021-03-20T19:21:27.750404 076 RP --- 01:201047 18:139815 --:------ 000A 006 011103E80960
2021-03-20T19:21:27.794420 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0504
2021-03-20T19:21:27.809652 077 RP --- 01:201047 18:139815 --:------ 000C 006 050400586D50
2021-03-20T19:21:27.856774 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0500
2021-03-20T19:21:27.872356 077 RP --- 01:201047 18:139815 --:------ 2349 007 05076C00FFFFFF
2021-03-20T19:21:27.915202 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000F
2021-03-20T19:21:27.930738 076 RP --- 01:201047 18:139815 --:------ 0005 004 000F0100
2021-03-20T19:21:27.976006 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0600
2021-03-20T19:21:28.520319 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0600
2021-03-20T19:21:28.533575 077 RP --- 01:201047 18:139815 --:------ 12B0 003 060000
2021-03-20T19:21:28.578084 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0700
2021-03-20T19:21:28.603196 077 RP --- 01:201047 18:139815 --:------ 000C 018 0700001099C30700001099C50700001099BF
2021-03-20T19:21:28.638860 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0000
2021-03-20T19:21:28.653526 076 RP --- 01:201047 18:139815 --:------ 12B0 003 000000
2021-03-20T19:21:28.698127 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0704
2021-03-20T19:21:28.715278 077 RP --- 01:201047 18:139815 --:------ 000C 006 070400587003
2021-03-20T19:21:28.758180 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0508
2021-03-20T19:21:28.773710 077 RP --- 01:201047 18:139815 --:------ 000C 006 0508001003B4
2021-03-20T19:21:28.819294 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0500
2021-03-20T19:21:28.836240 076 RP --- 01:201047 18:139815 --:------ 000A 006 051203E80960
2021-03-20T19:21:28.880900 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0000
2021-03-20T19:21:28.894487 075 RP --- 01:201047 18:139815 --:------ 30C9 003 00085F
2021-03-20T19:21:28.939041 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0700
2021-03-20T19:21:28.954078 077 RP --- 01:201047 18:139815 --:------ 000A 006 071003E80960
2021-03-20T19:21:28.996741 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0608
2021-03-20T19:21:29.547564 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0608
2021-03-20T19:21:29.568848 077 RP --- 01:201047 18:139815 --:------ 000C 012 06080010D26506080010D25D
2021-03-20T19:21:29.603417 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0204
2021-03-20T19:21:29.619883 076 RP --- 01:201047 18:139815 --:------ 000C 006 020400596077
2021-03-20T19:21:29.722023 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0004
2021-03-20T19:21:29.740282 076 RP --- 01:201047 18:139815 --:------ 000C 006 00047FFFFFFF
2021-03-20T19:21:29.782929 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0700
2021-03-20T19:21:29.800970 075 RP --- 01:201047 18:139815 --:------ 2349 007 0706A400FFFFFF
2021-03-20T19:21:29.840597 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0500
2021-03-20T19:21:29.859361 075 RP --- 01:201047 18:139815 --:------ 000C 006 0500001003B4
2021-03-20T19:21:29.960038 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0700
2021-03-20T19:21:29.974310 076 RP --- 01:201047 18:139815 --:------ 30C9 003 070766
2021-03-20T19:21:30.017771 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0108
2021-03-20T19:21:30.033248 075 RP --- 01:201047 18:139815 --:------ 000C 006 01087FFFFFFF
2021-03-20T19:21:30.068866 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0900
2021-03-20T19:21:30.085408 076 RP --- 01:201047 18:139815 --:------ 000C 006 0900001003B0
2021-03-20T19:21:30.127115 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0400
2021-03-20T19:21:30.668954 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0400
2021-03-20T19:21:30.685885 075 RP --- 01:201047 18:139815 --:------ 000A 006 041003E80960
2021-03-20T19:21:30.728459 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0700
2021-03-20T19:21:30.757236 075 RP --- 01:201047 18:139815 --:------ 0004 022 070053696D656F6E0000000000000000000000000000
2021-03-20T19:21:30.792424 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0000
2021-03-20T19:21:31.331530 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0000
2021-03-20T19:21:32.364911 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0000
2021-03-20T19:21:32.393785 077 RP --- 01:201047 18:139815 --:------ 0004 022 00004C6976696E670000000000000000000000000000
2021-03-20T19:21:32.426556 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0400
2021-03-20T19:21:33.460894 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0400
2021-03-20T19:21:33.481709 078 RP --- 01:201047 18:139815 --:------ 000C 012 0400001005CC0400001005AE
2021-03-20T19:21:33.519450 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0200
2021-03-20T19:21:33.535694 077 RP --- 01:201047 18:139815 --:------ 2349 007 02083400FFFFFF
2021-03-20T19:21:33.579860 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0500
2021-03-20T19:21:33.811179 061 I --- 04:179981 --:------ 04:179981 30C9 003 000A13
2021-03-20T19:21:34.350296 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0500
2021-03-20T19:21:34.910969 094 I --- 04:001454 --:------ 01:201047 3150 002 0400
2021-03-20T19:21:35.960706 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0500
2021-03-20T19:21:35.973565 076 RP --- 01:201047 18:139815 --:------ 12B0 003 050000
2021-03-20T19:21:36.015934 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0900
2021-03-20T19:21:36.314773 072 I --- 04:177712 --:------ 01:201047 3150 002 008A
2021-03-20T19:21:37.369522 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0900
2021-03-20T19:21:38.314843 070 I --- 04:177708 --:------ 01:201047 1060 003 00FF01
2021-03-20T19:21:38.326146 070 I --- 04:177708 --:------ 04:177708 1060 003 00FF01
2021-03-20T19:21:40.370898 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0900
2021-03-20T19:21:44.398401 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0400
2021-03-20T19:21:44.427824 077 RP --- 01:201047 18:139815 --:------ 0004 022 04004775657374204265640000000000000000000000
2021-03-20T19:21:44.456967 000 RQ --- 18:139815 01:201047 --:------ 2E04 001 FF
2021-03-20T19:21:44.477231 076 RP --- 01:201047 18:139815 --:------ 2E04 008 00FFFFFFFFFFFF00
2021-03-20T19:21:44.515679 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0000
2021-03-20T19:21:44.534576 076 RP --- 01:201047 18:139815 --:------ 2349 007 00083400FFFFFF
2021-03-20T19:21:44.573331 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0800
2021-03-20T19:21:45.120547 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0800
2021-03-20T19:21:45.135547 076 RP --- 01:201047 18:139815 --:------ 12B0 003 080000
2021-03-20T19:21:45.179206 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0208
2021-03-20T19:21:45.193666 076 RP --- 01:201047 18:139815 --:------ 000C 006 02087FFFFFFF
2021-03-20T19:21:45.233783 000 RQ --- 18:139815 01:201047 --:------ 0100 001 00
2021-03-20T19:21:45.248286 077 RP --- 01:201047 18:139815 --:------ 0100 005 00656EFFFF
2021-03-20T19:21:45.292274 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0400
2021-03-20T19:21:45.305388 076 RP --- 01:201047 18:139815 --:------ 30C9 003 0407D5
2021-03-20T19:21:45.346268 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0900
2021-03-20T19:21:45.887494 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0900
2021-03-20T19:21:46.924411 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0900
2021-03-20T19:21:48.842814 090 I --- 13:259021 --:------ 13:259021 3B00 002 00C8
2021-03-20T19:21:49.196544 077 I --- 01:201047 --:------ 01:201047 3B00 002 FCC8
2021-03-20T19:21:49.343534 087 I --- 13:259021 --:------ 13:259021 3EF0 003 00C8FF
2021-03-20T19:21:50.815300 074 I --- 04:177712 --:------ 01:201047 2309 003 000834
2021-03-20T19:21:51.812091 059 I --- 04:179866 --:------ 01:201047 2309 003 030834
2021-03-20T19:21:53.841048 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0008
2021-03-20T19:21:53.881155 077 RP --- 01:201047 18:139815 --:------ 000C 036 00080010999D00080010999900080010999700080010999B00080010D25B00080010D263
2021-03-20T19:21:53.921848 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0900
2021-03-20T19:21:53.943931 077 RP --- 01:201047 18:139815 --:------ 2349 013 09083404FFFFFF1E14140307E5
2021-03-20T19:21:53.977926 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0900
2021-03-20T19:21:54.518022 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0900
2021-03-20T19:21:55.557110 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0900
2021-03-20T19:21:55.583678 077 RP --- 01:201047 18:139815 --:------ 0004 022 09004769726C73204261746800000000000000000000
2021-03-20T19:21:55.639490 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0900
2021-03-20T19:21:56.668313 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0900
2021-03-20T19:21:56.683236 077 RP --- 01:201047 18:139815 --:------ 30C9 003 0907B1
2021-03-20T19:21:56.724919 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0300
2021-03-20T19:21:56.738793 077 RP --- 01:201047 18:139815 --:------ 12B0 003 030000
2021-03-20T19:21:56.785285 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0908
2021-03-20T19:21:56.801280 076 RP --- 01:201047 18:139815 --:------ 000C 006 0908001003B0
2021-03-20T19:21:56.843395 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0804
2021-03-20T19:21:56.860611 076 RP --- 01:201047 18:139815 --:------ 000C 006 0804005B577B
2021-03-20T19:21:56.904275 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0100
2021-03-20T19:21:56.933208 077 RP --- 01:201047 18:139815 --:------ 0004 022 01004D61737465722042656400000000000000000000
2021-03-20T19:21:56.983672 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000C
2021-03-20T19:21:56.997239 077 RP --- 01:201047 18:139815 --:------ 0005 004 000C0000
2021-03-20T19:21:57.040314 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0004
2021-03-20T19:21:57.571214 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0004
2021-03-20T19:21:57.586300 077 RP --- 01:201047 18:139815 --:------ 0005 004 0004FF0F
2021-03-20T19:21:57.626374 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0600
2021-03-20T19:21:57.655357 078 RP --- 01:201047 18:139815 --:------ 0004 022 060043656C6573746500000000000000000000000000
2021-03-20T19:21:57.690459 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0600
2021-03-20T19:21:58.231341 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0600
2021-03-20T19:21:58.268217 054 I --- 04:039323 --:------ 04:039323 30C9 003 0006D0
2021-03-20T19:21:59.317213 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0600
2021-03-20T19:22:00.121859 067 I --- 04:000950 --:------ 04:000950 30C9 003 000977
2021-03-20T19:22:01.312451 077 I --- 04:177711 --:------ 01:201047 1060 003 03FF01
2021-03-20T19:22:01.324498 079 I --- 04:177711 --:------ 04:177711 1060 003 00FF01
2021-03-20T19:22:02.309293 061 I --- 04:179981 --:------ 01:201047 3150 002 0190
2021-03-20T19:22:02.452257 078 I --- 22:027984 --:------ 22:027984 0008 002 00C8
2021-03-20T19:22:03.811067 062 I --- 04:173131 --:------ 01:201047 3150 002 0198
2021-03-20T19:22:04.815448 075 I --- 04:177712 --:------ 04:177712 30C9 003 0008B2
2021-03-20T19:22:06.854308 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0100
2021-03-20T19:22:06.870503 076 RP --- 01:201047 18:139815 --:------ 000C 006 01007FFFFFFF
2021-03-20T19:22:06.906639 000 RQ --- 18:139815 01:201047 --:------ 1F09 001 00
2021-03-20T19:22:06.920630 076 RP --- 01:201047 18:139815 --:------ 1F09 003 0004D8
2021-03-20T19:22:06.964571 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0A00
2021-03-20T19:22:07.070539 082 I --- 13:032522 --:------ 13:032522 3EF0 003 0000FF
2021-03-20T19:22:07.719753 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0A00
2021-03-20T19:22:07.735379 075 RP --- 01:201047 18:139815 --:------ 000A 006 0A1003E80960
2021-03-20T19:22:07.770622 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0700
2021-03-20T19:22:07.785761 075 RP --- 01:201047 18:139815 --:------ 12B0 003 070000
2021-03-20T19:22:07.828541 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0A00
2021-03-20T19:22:08.371378 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0A00
2021-03-20T19:22:08.401224 075 RP --- 01:201047 18:139815 --:------ 0004 022 0A00426F797320426174680000000000000000000000
2021-03-20T19:22:08.418254 082 RQ --- 34:046925 30:173916 --:------ 2349 001 00
2021-03-20T19:22:08.454281 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0500
2021-03-20T19:22:08.468929 075 RP --- 01:201047 18:139815 --:------ 30C9 003 0507C9
2021-03-20T19:22:08.511158 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0A00
2021-03-20T19:22:08.523266 075 RP --- 01:201047 18:139815 --:------ 12B0 003 0A0000
2021-03-20T19:22:08.544442 027 RP --- 30:173916 34:046925 --:------ 2349 013 00051402FFFFFFFFFFFFFFFFFF
2021-03-20T19:22:08.566258 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0300
2021-03-20T19:22:09.101554 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0300
2021-03-20T19:22:10.138383 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0300
2021-03-20T19:22:11.811713 052 I --- 04:177713 --:------ 01:201047 3150 002 0240
2021-03-20T19:22:12.812549 063 I --- 04:179866 --:------ 04:179866 30C9 003 0005EB
2021-03-20T19:22:14.855196 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0A00
2021-03-20T19:22:14.868727 077 RP --- 01:201047 18:139815 --:------ 30C9 003 0A086C
2021-03-20T19:22:14.908400 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0A08
2021-03-20T19:22:14.924420 077 RP --- 01:201047 18:139815 --:------ 000C 006 0A08001003B2
2021-03-20T19:22:14.963308 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0408
2021-03-20T19:22:15.502033 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0408
2021-03-20T19:22:15.522062 076 RP --- 01:201047 18:139815 --:------ 000C 012 0408001005CC0408001005AE
2021-03-20T19:22:15.557230 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0500
2021-03-20T19:22:15.587703 076 RP --- 01:201047 18:139815 --:------ 0004 022 05004775657374204261746800000000000000000000
2021-03-20T19:22:15.620595 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0B04
2021-03-20T19:22:15.637092 075 RP --- 01:201047 18:139815 --:------ 000C 006 0B0400586D45
2021-03-20T19:22:15.673591 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0600
2021-03-20T19:22:15.694220 075 RP --- 01:201047 18:139815 --:------ 000C 012 06000010D26506000010D25D
2021-03-20T19:22:15.727114 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0104
2021-03-20T19:22:15.743148 076 RP --- 01:201047 18:139815 --:------ 000C 006 010400596073
2021-03-20T19:22:15.780009 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0B00
2021-03-20T19:22:15.809578 076 RP --- 01:201047 18:139815 --:------ 0004 022 0B00506C6179726F6F6D000000000000000000000000
2021-03-20T19:22:15.862799 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0100
2021-03-20T19:22:15.876103 074 RP --- 01:201047 18:139815 --:------ 12B0 003 010000
2021-03-20T19:22:15.920610 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0B00
2021-03-20T19:22:16.452880 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0B00
2021-03-20T19:22:16.468860 076 RP --- 01:201047 18:139815 --:------ 000A 006 0B1103E80960
2021-03-20T19:22:16.507391 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0300
2021-03-20T19:22:16.520879 077 RP --- 01:201047 18:139815 --:------ 30C9 003 030828
2021-03-20T19:22:16.564896 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0200
2021-03-20T19:22:16.580930 074 RP --- 01:201047 18:139815 --:------ 000C 006 02007FFFFFFF
2021-03-20T19:22:16.622077 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0A00
2021-03-20T19:22:16.639058 077 RP --- 01:201047 18:139815 --:------ 2349 007 0A089800FFFFFF
2021-03-20T19:22:16.677158 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0200
2021-03-20T19:22:16.690815 076 RP --- 01:201047 18:139815 --:------ 30C9 003 020854
2021-03-20T19:22:16.733915 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0B00
2021-03-20T19:22:16.751564 075 RP --- 01:201047 18:139815 --:------ 2349 007 0B06A400FFFFFF
2021-03-20T19:22:16.789888 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0800
2021-03-20T19:22:16.804246 077 RP --- 01:201047 18:139815 --:------ 30C9 003 0807B0
2021-03-20T19:22:16.844960 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0808
2021-03-20T19:22:16.861969 076 RP --- 01:201047 18:139815 --:------ 000C 006 0808001003B6
2021-03-20T19:22:16.901976 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0708
2021-03-20T19:22:16.927986 077 RP --- 01:201047 18:139815 --:------ 000C 018 0708001099C30708001099C50708001099BF
2021-03-20T19:22:16.980814 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0800
2021-03-20T19:22:17.515690 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0800
2021-03-20T19:22:17.531694 073 RP --- 01:201047 18:139815 --:------ 000C 006 0800001003B6
2021-03-20T19:22:17.572350 000 RQ --- 18:139815 01:201047 --:------ 000A 002 0800
2021-03-20T19:22:17.587794 074 RP --- 01:201047 18:139815 --:------ 000A 006 081103E80960
2021-03-20T19:22:17.686757 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0800
2021-03-20T19:22:17.716637 074 RP --- 01:201047 18:139815 --:------ 0004 022 08004D696D69652D526F736500000000000000000000
2021-03-20T19:22:17.770650 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0800
2021-03-20T19:22:17.787731 074 RP --- 01:201047 18:139815 --:------ 2349 007 0806A400FFFFFF
2021-03-20T19:22:17.826834 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0904
2021-03-20T19:22:17.842711 075 RP --- 01:201047 18:139815 --:------ 000C 006 090400587057
2021-03-20T19:22:17.881670 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0A04
2021-03-20T19:22:18.434534 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0A04
2021-03-20T19:22:18.449616 075 RP --- 01:201047 18:139815 --:------ 000C 006 0A040059605F
2021-03-20T19:22:18.488752 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0A00
2021-03-20T19:22:18.504664 074 RP --- 01:201047 18:139815 --:------ 000C 006 0A00001003B2
2021-03-20T19:22:18.546506 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0B00
2021-03-20T19:22:18.562611 074 RP --- 01:201047 18:139815 --:------ 000C 006 0B00001099C1
2021-03-20T19:22:18.601675 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0B00
2021-03-20T19:22:18.615668 074 RP --- 01:201047 18:139815 --:------ 12B0 003 0B0000
2021-03-20T19:22:18.656821 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0300
2021-03-20T19:22:18.672612 074 RP --- 01:201047 18:139815 --:------ 000C 006 03007FFFFFFF
2021-03-20T19:22:18.713545 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0B00
2021-03-20T19:22:18.728231 074 RP --- 01:201047 18:139815 --:------ 30C9 003 0B0812
2021-03-20T19:22:18.770148 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0400
2021-03-20T19:22:18.786957 074 RP --- 01:201047 18:139815 --:------ 2349 007 04076C00FFFFFF
2021-03-20T19:22:18.827541 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0604
2021-03-20T19:22:19.355367 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0604
2021-03-20T19:22:19.371404 074 RP --- 01:201047 18:139815 --:------ 000C 006 060400587048
2021-03-20T19:22:19.410529 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0600
2021-03-20T19:22:19.426530 075 RP --- 01:201047 18:139815 --:------ 2349 007 0606A400FFFFFF
2021-03-20T19:22:19.467343 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0600
2021-03-20T19:22:19.481789 075 RP --- 01:201047 18:139815 --:------ 30C9 003 0607EC
2021-03-20T19:22:19.522340 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0B08
2021-03-20T19:22:19.538330 075 RP --- 01:201047 18:139815 --:------ 000C 006 0B08001099C1
2021-03-20T19:22:19.576334 000 RQ --- 18:139815 13:032522 --:------ 1100 001 00
2021-03-20T19:22:20.118249 000 RQ --- 18:139815 13:032522 --:------ 1100 001 00
2021-03-20T19:22:21.169266 000 RQ --- 18:139815 13:032522 --:------ 1100 001 00
2021-03-20T19:22:21.186386 086 RP --- 13:032522 18:139815 --:------ 1100 008 00180404007FFF01
2021-03-20T19:22:21.228169 000 RQ --- 18:139815 13:032522 --:------ 0008 001 00
2021-03-20T19:22:21.239247 086 RP --- 13:032522 18:139815 --:------ 0008 002 0000
2021-03-20T19:22:21.284307 000 RQ --- 18:139815 13:032522 --:------ 3EF1 001 00
2021-03-20T19:22:21.828940 000 RQ --- 08:000730 13:032522 --:------ 3EF1 001 00
2021-03-20T19:22:21.844007 083 RP --- 13:032522 08:000730 --:------ 3EF1 007 00024A024A00FF
2021-03-20T19:22:21.884163 000 RQ --- 18:139815 30:173916 --:------ 10E0 001 00
2021-03-20T19:22:22.018896 026 RP --- 30:173916 18:139815 --:------ 10E0 038 000002FF1E03FFFFFFFF190507E4150407E1496E7465726E6574204761746577617900000000
2021-03-20T19:22:22.128014 000 RQ --- 18:139815 13:259021 --:------ 3EF1 001 00
2021-03-20T19:22:22.144660 091 RP --- 13:259021 18:139815 --:------ 3EF1 007 00010C010CC8FF
2021-03-20T19:22:22.184389 000 RQ --- 18:139815 13:259021 --:------ 0008 001 00
2021-03-20T19:22:22.306878 060 I --- 04:173146 --:------ 01:201047 3150 002 035E
2021-03-20T19:22:22.858900 000 RQ --- 18:139815 13:259021 --:------ 0008 001 00
2021-03-20T19:22:22.870388 091 RP --- 13:259021 18:139815 --:------ 0008 002 007E
2021-03-20T19:22:22.912997 000 RQ --- 18:139815 13:032522 --:------ 3EF1 001 00
2021-03-20T19:22:23.456679 000 RQ --- 18:139815 31:032522 --:------ 3EF1 001 00
2021-03-20T19:22:23.652965 000 RQ --- 18:139815 13:032522 --:------ 0008 001 00
client.py: Finished evohome_rf, results:
Schema[01:201047 (evohome)] = {
"controller": "01:201047",
"system": {
"heating_relay": "13:259021"
"orphans": [
"04:173125",
"04:173127",
"04:173131",
"04:173146",
"04:177708",
"04:177711",
"04:177712",
"04:177713",
"04:177718",
"04:179866",
"04:179981"
"stored_hotwater": {},
"underfloor_heating": {},
"zones": {
"00": {
"heating_type": "radiator_valve",
"sensor": null,
"devices": [
"04:039325",
"04:039321",
"04:039319",
"04:039323",
"04:053851",
"04:053859"
"01": {
"sensor": "22:090227",
"devices": [
"22:090227"
"02": {
"sensor": "22:090231",
"devices": [
"22:090231"
"03": {
"sensor": "22:028749",
"devices": [
"22:028749"
"04": {
"sensor": "22:028665",
"devices": [
"22:028665",
"04:001484",
"04:001454"
"05": {
"sensor": "22:027984",
"devices": [
"22:027984",
"04:000948"
"06": {
"sensor": "22:028744",
"devices": [
"04:053861",
"04:053853",
"22:028744"
"07": {
"sensor": "22:028675",
"devices": [
"04:039363",
"04:039365",
"04:039359",
"22:028675"
"08": {
"sensor": "22:219003",
"devices": [
"22:219003",
"04:000950"
"09": {
"sensor": "22:028759",
"devices": [
"04:000944",
"22:028759"
"0A": {
"sensor": "22:090207",
"devices": [
"04:000946",
"22:090207"
"0B": {
"sensor": "22:027973",
"devices": [
"22:027973",
"04:039361"
Thatās a bit odd - I did have a HR80, but not presentlyā¦
Try this & send me the packet log:
python client.py execute /dev/ttyUSB0 -o scan_full.log -sf 01:201047
The scan may take 5 minutes - you will get lots of errors - it will have finished when you see something like this: full scan: ended
21:42:24.266 || HGI:140805 | NUL:262142 | I | puzzle_packet | 00003... || {'datetime': '21-03-20T21:40:38', 'message': 'full scan: ended'}
2021-03-20T22:55:27.569643 # evofw3 0.6.16
2021-03-20T22:55:27.599061 000 I --- 18:139815 63:262142 --:------ 7FFF 008 0176302E372E317F
2021-03-20T22:55:27.633649 000 RQ --- 18:139815 01:201047 --:------ 0016 002 00FF
2021-03-20T22:55:27.644946 080 RP --- 01:201047 18:139815 --:------ 0016 002 000A
2021-03-20T22:55:27.718746 000 I --- 18:139815 63:262142 --:------ 7FFF 024 00003A15B6ED807F66756C6C207363616E3A20626567696E
2021-03-20T22:55:27.751972 000 RQ --- 18:139815 01:201047 --:------ 0016 002 0000
2021-03-20T22:55:27.765673 079 RP --- 01:201047 18:139815 --:------ 0016 002 000A
2021-03-20T22:55:27.809234 000 RQ --- 18:139815 01:201047 --:------ 0001 002 0000
2021-03-20T22:55:27.865257 000 RQ --- 18:139815 01:201047 --:------ 0002 002 0000
2021-03-20T22:55:27.879591 080 RP --- 01:201047 18:139815 --:------ 0002 004 007FFF01
2021-03-20T22:55:27.921806 000 RQ --- 18:139815 01:201047 --:------ 0004 002 0000
2021-03-20T22:55:27.951027 080 RP --- 01:201047 18:139815 --:------ 0004 022 00004C6976696E670000000000000000000000000000
2021-03-20T22:55:28.007206 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0000
2021-03-20T22:55:28.021806 080 RP --- 01:201047 18:139815 --:------ 0005 004 0000FF0F
2021-03-20T22:55:28.063296 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0001
2021-03-20T22:55:28.076632 081 RP --- 01:201047 18:139815 --:------ 0005 004 00010000
2021-03-20T22:55:28.119320 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0002
2021-03-20T22:55:28.658113 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0002
2021-03-20T22:55:29.689946 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0003
2021-03-20T22:55:30.223957 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0003
2021-03-20T22:55:31.095270 049 I --- 04:177713 --:------ 04:177713 30C9 003 000789
2021-03-20T22:55:31.591892 058 I --- 04:179866 --:------ 01:201047 3150 002 036E
2021-03-20T22:55:32.106382 049 I --- 04:177713 --:------ 04:177713 1060 003 00FF01
2021-03-20T22:55:33.090702 094 I --- 04:177718 --:------ 01:201047 1060 003 00FF01
2021-03-20T22:55:34.129364 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0004
2021-03-20T22:55:34.664900 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0004
2021-03-20T22:55:35.595241 075 I --- 04:177708 --:------ 04:177708 30C9 003 000AEA
2021-03-20T22:55:36.637614 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0006
2021-03-20T22:55:37.171123 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0006
2021-03-20T22:55:37.590624 068 I --- 04:177711 --:------ 01:201047 3150 002 036A
2021-03-20T22:55:38.624670 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000B
2021-03-20T22:55:38.641038 086 RP --- 01:201047 18:139815 --:------ 0005 004 000B0000
2021-03-20T22:55:38.677770 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000E
2021-03-20T22:55:38.694243 085 RP --- 01:201047 18:139815 --:------ 0005 004 000E0000
2021-03-20T22:55:38.746235 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0011
2021-03-20T22:55:38.758670 086 RP --- 01:201047 18:139815 --:------ 0005 004 00110000
2021-03-20T22:55:38.869881 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0200
2021-03-20T22:55:39.168567 081 RP --- 13:032522 34:046925 --:------ 3EF1 007 000185018500FF
2021-03-20T22:55:40.198424 000 RQ --- 18:139815 01:201047 --:------ 000E 002 0000
2021-03-20T22:55:40.748128 000 RQ --- 18:139815 01:201047 --:------ 000E 002 0000
2021-03-20T22:55:41.783000 000 RQ --- 18:139815 01:201047 --:------ 0418 003 000001
2021-03-20T22:55:41.811274 085 RP --- 01:201047 18:139815 --:------ 0418 022 004001B00607040000003A153B8A7FFFFF70001099C3
2021-03-20T22:55:41.864103 000 RQ --- 18:139815 01:201047 --:------ 1090 002 0000
2021-03-20T22:55:42.416484 000 RQ --- 18:139815 01:201047 --:------ 1090 002 0000
2021-03-20T22:55:43.451136 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000F
2021-03-20T22:55:43.996838 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000F
2021-03-20T22:55:44.095006 049 I --- 04:177713 --:------ 04:177713 30C9 003 000789
2021-03-20T22:55:45.127873 000 RQ --- 18:139815 01:201047 --:------ 10E0 002 0000
2021-03-20T22:55:45.670412 000 RQ --- 18:139815 01:201047 --:------ 10E0 002 0000
2021-03-20T22:55:46.700470 000 RQ --- 18:139815 01:201047 --:------ 0009 002 0000
2021-03-20T22:55:47.244528 000 RQ --- 18:139815 01:201047 --:------ 0009 002 0000
2021-03-20T22:55:48.287302 000 RQ --- 18:139815 01:201047 --:------ 1100 001 FC
2021-03-20T22:55:48.830300 000 RQ --- 18:139815 01:201047 --:------ 1100 001 FC
2021-03-20T22:55:48.849146 086 RP --- 01:201047 18:139815 --:------ 1100 008 FC301400007FFF01
2021-03-20T22:55:48.889060 000 RQ --- 18:139815 01:201047 --:------ 1F09 001 00
2021-03-20T22:55:48.903404 085 RP --- 01:201047 18:139815 --:------ 1F09 003 0002DA
2021-03-20T22:55:48.949670 000 RQ --- 18:139815 01:201047 --:------ 1FD4 002 0000
2021-03-20T22:55:49.485732 000 RQ --- 18:139815 01:201047 --:------ 1FD4 002 0000
2021-03-20T22:55:50.484483 050 I --- 22:028749 --:------ 22:028749 0008 002 00C8
2021-03-20T22:55:50.601911 078 I --- 04:039361 --:------ 01:201047 12B0 003 0B0000
2021-03-20T22:55:51.093474 075 I --- 04:177708 --:------ 01:201047 3150 002 00BE
2021-03-20T22:55:52.111291 076 I --- 04:177712 --:------ 04:177712 1060 003 00FF01
2021-03-20T22:55:52.129157 000 RQ --- 18:139815 01:201047 --:------ 1030 002 0000
2021-03-20T22:55:52.485236 050 I --- 22:028749 --:------ 22:028749 0008 002 00C8
2021-03-20T22:55:53.015587 000 RQ --- 18:139815 01:201047 --:------ 1030 002 0000
2021-03-20T22:55:53.418489 077 I --- 04:039361 --:------ 01:201047 12B0 003 0B0000
2021-03-20T22:55:54.455115 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0010
2021-03-20T22:55:54.468941 081 RP --- 01:201047 18:139815 --:------ 0005 004 00100000
2021-03-20T22:55:54.515121 000 RQ --- 18:139815 01:201047 --:------ 2249 002 0000
2021-03-20T22:55:55.067861 000 RQ --- 18:139815 01:201047 --:------ 2249 002 0000
2021-03-20T22:55:56.108527 000 RQ --- 18:139815 01:201047 --:------ 01D0 002 0000
2021-03-20T22:55:56.643021 000 RQ --- 18:139815 01:201047 --:------ 01D0 002 0000
2021-03-20T22:55:57.093295 049 I --- 04:177713 --:------ 01:201047 3150 002 0200
2021-03-20T22:55:57.593924 073 I --- 04:173127 --:------ 04:173127 30C9 003 0006EE
2021-03-20T22:55:58.627223 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0C00
2021-03-20T22:55:59.162365 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0C00
2021-03-20T22:56:00.193947 000 RQ --- 18:139815 01:201047 --:------ 22C9 002 0000
2021-03-20T22:56:00.736830 000 RQ --- 18:139815 01:201047 --:------ 22C9 002 0000
2021-03-20T22:56:01.775991 000 RQ --- 18:139815 01:201047 --:------ 22F1 002 0000
2021-03-20T22:56:02.316555 000 RQ --- 18:139815 01:201047 --:------ 22F1 002 0000
2021-03-20T22:56:03.371654 000 RQ --- 18:139815 01:201047 --:------ 2309 001 00
2021-03-20T22:56:03.914338 000 RQ --- 18:139815 01:020147 --:------ 2309 001 00
2021-03-20T22:56:04.066262 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0900
2021-03-20T22:56:04.080899 084 RP --- 01:201047 18:139815 --:------ 000C 006 0900001003B0
2021-03-20T22:56:04.125894 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0600
2021-03-20T22:56:04.673306 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0600
2021-03-20T22:56:04.694376 083 RP --- 01:201047 18:139815 --:------ 000C 012 06000010D26506000010D25D
2021-03-20T22:56:04.732467 000 RQ --- 18:139815 01:201047 --:------ 22D9 002 0000
2021-03-20T22:56:05.278985 000 RQ --- 18:139815 01:201047 --:------ 22D9 002 0000
2021-03-20T22:56:06.092195 073 I --- 04:173127 --:------ 01:201047 3150 002 0200
2021-03-20T22:56:07.140731 000 RQ --- 18:139815 01:201047 --:------ 2349 002 0000
2021-03-20T22:56:07.158026 086 RP --- 01:201047 18:139815 --:------ 2349 007 00083400FFFFFF
2021-03-20T22:56:07.198291 000 RQ --- 18:139815 01:201047 --:------ 1FC9 001 00
2021-03-20T22:56:07.739376 000 RQ --- 18:139815 01:201047 --:------ 1FC9 001 00
2021-03-20T22:56:08.787595 000 RQ --- 18:139815 01:201047 --:------ 2D49 002 0000
2021-03-20T22:56:09.332656 000 RQ --- 18:139815 01:201047 --:------ 2D49 002 0000
2021-03-20T22:56:10.093089 057 I --- 04:179866 --:------ 04:179866 30C9 003 0005FA
2021-03-20T22:56:10.593269 060 I --- 04:173146 --:------ 01:201047 1060 003 03FF01
2021-03-20T22:56:10.604079 060 I --- 04:173146 --:------ 04:173146 1060 003 00FF01
2021-03-20T22:56:11.643307 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0000
2021-03-20T22:56:12.176843 000 RQ --- 18:139815 01:201047 --:------ 30C9 002 0000
2021-03-20T22:56:13.222942 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0008
2021-03-20T22:56:13.760018 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0008
2021-03-20T22:56:14.593302 057 I --- 04:179866 --:------ 01:201047 1060 003 03FF01
2021-03-20T22:56:14.604406 057 I --- 04:179866 --:------ 04:179866 1060 003 00FF01
2021-03-20T22:56:15.638389 000 RQ --- 18:139815 01:201047 --:------ 0006 001 00
2021-03-20T22:56:16.184245 000 RQ --- 18:139815 01:201047 --:------ 0006 001 00
2021-03-20T22:56:17.229028 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0000
2021-03-20T22:56:17.268325 087 RP --- 01:201047 18:139815 --:------ 000C 036 00000010999D00000010999900000010999700000010999B00000010D25B00000010D263
2021-03-20T22:56:17.315010 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0400
2021-03-20T22:56:17.851020 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0400
2021-03-20T22:56:17.873221 085 RP --- 01:201047 18:139815 --:------ 000C 012 0400001005CC0400001005AE
2021-03-20T22:56:17.909514 000 RQ --- 18:139815 01:201047 --:------ 000A 003 000000
2021-03-20T22:56:18.451996 000 RQ --- 18:139815 01:201047 --:------ 000A 003 000000
2021-03-20T22:56:18.591808 054 I --- 04:173125 --:------ 01:201047 3150 002 0100
2021-03-20T22:56:19.620644 000 RQ --- 18:139815 01:201047 --:------ 0008 002 0000
2021-03-20T22:56:20.159981 000 RQ --- 18:139815 01:201047 --:------ 0008 002 0000
2021-03-20T22:56:21.198684 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0009
2021-03-20T22:56:21.215495 082 RP --- 01:201047 18:139815 --:------ 0005 004 00090000
2021-03-20T22:56:21.253304 000 RQ --- 18:139815 01:201047 --:------ 10A0 002 0000
2021-03-20T22:56:21.594177 075 I --- 04:177708 --:------ 01:201047 2309 003 000834
2021-03-20T22:56:22.131273 000 RQ --- 18:139815 01:201047 --:------ 10A0 002 0000
2021-03-20T22:56:22.593018 053 I --- 04:173125 --:------ 04:173125 30C9 003 000795
2021-03-20T22:56:23.638916 000 RQ --- 18:139815 01:201047 --:------ 1280 002 0000
2021-03-20T22:56:24.175368 000 RQ --- 18:139815 01:201047 --:------ 1280 002 0000
2021-03-20T22:56:25.209887 000 RQ --- 18:139815 01:201047 --:------ 3120 002 0000
2021-03-20T22:56:25.742740 000 RQ --- 18:139815 01:201047 --:------ 3120 002 0000
2021-03-20T22:56:26.778248 000 RQ --- 18:139815 01:201047 --:------ 0B04 002 0000
2021-03-20T22:56:27.316683 000 RQ --- 18:139815 01:201047 --:------ 0B04 002 0000
2021-03-20T22:56:28.344033 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000D
2021-03-20T22:56:28.358191 082 RP --- 01:201047 18:139815 --:------ 0005 004 000D0000
2021-03-20T22:56:28.400120 000 RQ --- 18:139815 01:201047 --:------ 313F 002 0000
2021-03-20T22:56:28.418238 082 RP --- 01:201047 18:139815 --:------ 313F 009 00FC2439B6140307E5
2021-03-20T22:56:28.458042 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0D00
2021-03-20T22:56:28.472993 083 RP --- 01:201047 18:139815 --:------ 000C 006 0D007FFFFFFF
2021-03-20T22:56:28.520804 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0300
2021-03-20T22:56:28.535082 082 RP --- 01:201047 18:139815 --:------ 000C 006 03007FFFFFFF
2021-03-20T22:56:28.579031 000 RQ --- 18:139815 01:201047 --:------ 31D9 002 0000
2021-03-20T22:56:29.119981 000 RQ --- 18:139815 01:201047 --:------ 31D9 002 0000
2021-03-20T22:56:30.158856 000 RQ --- 08:000730 01:201047 --:------ 0005 002 0013
2021-03-20T22:56:30.252155 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0013
2021-03-20T22:56:31.092496 067 I --- 04:177711 --:------ 04:177711 30C9 003 0008F3
2021-03-20T22:56:32.136485 000 RQ --- 18:139815 01:201047 --:------ 1260 002 0000
2021-03-20T22:56:32.149497 082 RP --- 01:201047 18:139815 --:------ 1260 003 007FFF
2021-03-20T22:56:32.189504 000 RQ --- 18:139815 01:201047 --:------ 3150 002 0000
2021-03-20T22:56:32.593866 073 I --- 04:173127 --:------ 01:201047 2309 003 0206A4
2021-03-20T22:56:33.092143 053 I --- 04:173125 --:------ 04:173125 30C9 003 00078F
2021-03-20T22:56:33.594107 075 I --- 04:177708 --:------ 04:177708 30C9 003 000AEA
2021-03-20T22:56:34.139054 000 RQ --- 18:139815 01:201047 --:------ 3150 002 0000
2021-03-20T22:56:34.593970 075 I --- 04:177708 --:------ 01:201047 2309 003 000834
2021-03-20T22:56:35.639095 000 RQ --- 18:000030 01:201047 --:------ 000C 002 0A00
2021-03-20T22:56:35.655056 081 RP --- 01:201047 18:000030 --:------ 000C 006 0A00001003B2
2021-03-20T22:56:35.692761 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0E00
2021-03-20T22:56:35.708970 082 RP --- 01:201047 18:139815 --:------ 000C 006 0E007FFFFFFF
2021-03-20T22:56:35.748510 000 RQ --- 18:139815 01:201047 --:------ 31DA 002 0000
2021-03-20T22:56:36.291747 000 RQ --- 18:139815 01:201047 --:------ 31DA 002 0000
2021-03-20T22:56:37.335675 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0005
2021-03-20T22:56:37.594410 049 I --- 04:177713 --:------ 01:201047 1060 003 02FF01
2021-03-20T22:56:37.605515 049 I --- 04:177713 --:------ 04:177713 1060 003 00FF01
2021-03-20T22:56:38.144049 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0005
2021-03-20T22:56:39.184220 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0500
2021-03-20T22:56:39.721185 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0500
2021-03-20T22:56:39.738781 081 RP --- 01:201047 18:139815 --:------ 000C 006 0500001003B4
2021-03-20T22:56:39.780134 000 RQ --- 18:139815 01:201047 --:------ 0100 002 0000
2021-03-20T22:56:39.795234 081 RP --- 01:201047 18:139815 --:------ 0100 005 00656EFFFF
2021-03-20T22:56:39.836155 000 RQ --- 18:139815 01:201047 --:------ 31E0 002 0000
2021-03-20T22:56:40.368065 000 RQ --- 18:139815 01:201047 --:------ 31E0 002 0000
2021-03-20T22:56:41.406428 000 RQ --- 18:139815 01:201047 --:------ 042F 002 0000
2021-03-20T22:56:41.940802 000 RQ --- 18:139815 01:201047 --:------ 042F 002 0000
2021-03-20T22:56:42.342649 055 I --- 22:090227 --:------ 22:090227 0008 002 0000
2021-03-20T22:56:42.593540 069 I --- 04:177711 --:------ 01:201047 1060 003 03FF01
2021-03-20T22:56:42.604526 069 I --- 04:177711 --:------ 04:177711 1060 003 00FF01
2021-03-20T22:56:43.643066 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000C
2021-03-20T22:56:43.657498 081 RP --- 01:201047 18:139815 --:------ 0005 004 000C0000
2021-03-20T22:56:43.699652 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0100
2021-03-20T22:56:44.233904 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0100
2021-03-20T22:56:44.250596 081 RP --- 01:201047 18:139815 --:------ 000C 006 01007FFFFFFF
2021-03-20T22:56:44.290477 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0700
2021-03-20T22:56:44.825383 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0700
2021-03-20T22:56:45.862170 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0800
2021-03-20T22:56:46.341924 056 I --- 22:090227 --:------ 22:090227 0008 002 0000
2021-03-20T22:56:46.890001 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0800
2021-03-20T22:56:47.942994 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0B00
2021-03-20T22:56:47.959028 080 RP --- 01:201047 18:139815 --:------ 000C 006 0B00001099C1
2021-03-20T22:56:48.056787 000 RQ --- 18:139815 01:201047 --:------ 1060 002 0000
2021-03-20T22:56:49.100699 000 RQ --- 18:139815 01:201047 --:------ 1290 002 0000
2021-03-20T22:56:49.113508 084 RP --- 01:201047 18:139815 --:------ 1290 003 00004E
2021-03-20T22:56:49.158659 000 RQ --- 18:139815 01:201047 --:------ 12A0 002 0000
2021-03-20T22:56:49.357385 084 I --- 13:259021 --:------ 13:259021 3B00 002 00C8
2021-03-20T22:56:49.558345 086 I --- 13:259021 --:------ 13:259021 3EF0 003 00C8FF
2021-03-20T22:56:50.099405 000 RQ --- 18:139815 01:201047 --:------ 12A0 002 0000
2021-03-20T22:56:51.205270 000 RQ --- 18:139815 01:201047 --:------ 12B0 002 0000
2021-03-20T22:56:51.591991 068 I --- 04:177711 --:------ 04:177711 30C9 003 0008F3
2021-03-20T22:56:52.094922 091 I --- 04:179995 --:------ 04:179995 30C9 003 000B3F
2021-03-20T22:56:53.094726 076 I --- 04:177708 --:------ 01:201047 1060 003 00FF01
2021-03-20T22:56:53.105729 075 I --- 04:177708 --:------ 04:177708 1060 003 00FF01
2021-03-20T22:56:55.051473 000 RQ --- 18:139815 01:201047 --:------ 12C0 002 0000
2021-03-20T22:56:55.058590 000 RQ --- 18:139815 01:201047 --:------ 12C0 002 0000
2021-03-20T22:56:55.064586 000 RQ --- 18:139815 01:201047 --:------ 0005 002 000A
2021-03-20T22:56:55.073757 081 RP --- 01:201047 18:139815 --:------ 0005 004 000A0000
2021-03-20T22:56:55.163548 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0007
2021-03-20T22:56:55.565317 081 I --- 01:201047 --:------ 01:201047 3B00 002 FCC8
2021-03-20T22:56:55.591428 062 I --- 04:179981 --:------ 01:201047 2309 003 010640
2021-03-20T22:56:56.683293 000 RQ --- 18:139815 01:201047 --:------ 0005 002 0012
2021-03-20T22:56:57.724103 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0F00
2021-03-20T22:56:57.740424 080 RP --- 01:201047 18:139815 --:------ 000C 006 0F007FFFFFFF
2021-03-20T22:56:57.779038 000 RQ --- 18:139815 01:201047 --:------ 01E9 002 0000
2021-03-20T22:56:58.092920 053 I --- 04:173125 --:------ 01:201047 1060 003 01FF01
2021-03-20T22:56:58.105369 053 I --- 04:173125 --:------ 04:173125 1060 003 00FF01
2021-03-20T22:56:58.654912 000 RQ --- 18:139815 01:201047 --:------ 01E9 002 0000
2021-03-20T22:56:59.594756 063 I --- 04:173131 --:------ 01:201047 1060 003 01FF01
2021-03-20T22:56:59.605750 063 I --- 04:173131 --:------ 04:173131 1060 003 00FF01
2021-03-20T22:57:00.662479 000 RQ --- 18:139815 01:201047 --:------ 0404 007 00200008000100
2021-03-20T22:57:00.719326 081 RP --- 01:201047 18:139815 --:------ 0404 048 0020000829010268816DCA311100210C05D11F2019F08320B450A0E4A49C303AA0D82D779E745B26F53ADAB3345DFAE2
2021-03-20T22:57:00.769242 000 RQ --- 18:139815 01:201047 --:------ 0418 003 000000
2021-03-20T22:57:00.796592 081 RP --- 01:201047 18:139815 --:------ 0418 022 000000B00409040000003A1591C77FFFFF70001003B0
2021-03-20T22:57:00.849739 000 RQ --- 18:139815 01:201047 --:------ 1F41 002 0000
2021-03-20T22:57:00.866113 080 RP --- 01:201047 18:139815 --:------ 1F41 006 00FF00FFFFFF
2021-03-20T22:57:00.911496 000 RQ --- 18:139815 01:201047 --:------ 3220 005 0000000000
2021-03-20T22:57:01.456314 000 RQ --- 18:139815 01:201047 --:------ 3220 005 0000000000
2021-03-20T22:57:02.161189 081 I --- 01:201047 --:------ 01:201047 1F09 003 FF078F
2021-03-20T22:57:02.211335 081 I --- 01:201047 --:------ 01:201047 000A 048 001203E80960011103E80960021003E80960031103E80960041003E80960051203E80960061103E80960071003E80960
2021-03-20T22:57:02.224590 082 I --- 01:201047 --:------ 01:201047 000A 024 081103E80960091203E809600A1003E809600B1103E80960
2021-03-20T22:57:03.087066 055 RQ --- 22:028744 01:201047 --:------ 2309 003 0606A4
2021-03-20T22:57:03.110111 073 RQ --- 22:219003 01:201047 --:------ 2309 003 0806A4
2021-03-20T22:57:03.124244 080 RP --- 01:201047 22:219003 --:------ 2309 003 0806A4
2021-03-20T22:57:04.176861 000 RQ --- 18:139815 01:201047 --:------ 3220 005 0000030000
2021-03-20T22:57:04.261867 066 I --- 04:039323 --:------ 63:262142 3150 002 001E
2021-03-20T22:57:04.813869 000 RQ --- 18:139815 01:201047 --:------ 3220 005 0000030000
2021-03-20T22:57:05.846684 000 RQ --- 18:139815 01:201047 --:------ 3B00 002 0000
2021-03-20T22:57:05.903679 073 I --- 22:027973 --:------ 22:027973 0008 002 00C8
2021-03-20T22:57:06.457041 000 RQ --- 18:139815 01:201047 --:------ 3B00 002 0000
2021-03-20T22:57:06.587469 070 RQ --- 22:028665 01:201047 --:------ 2309 003 0406A4
2021-03-20T22:57:06.601878 081 RP --- 01:201047 22:028665 --:------ 2309 003 0406A4
2021-03-20T22:57:07.089337 066 RQ --- 22:028759 01:201047 --:------ 2309 003 0906A4
2021-03-20T22:57:07.102356 083 RP --- 01:201047 22:028759 --:------ 2309 003 0906A4
2021-03-20T22:57:07.903237 072 I --- 22:027973 --:------ 22:027973 0008 002 00C8
2021-03-20T22:57:08.939123 000 RQ --- 18:139815 01:201047 --:------ 3EF0 002 0000
2021-03-20T22:57:09.477117 000 RQ --- 18:139815 01:201047 --:------ 3EF0 002 0000
2021-03-20T22:57:10.519690 000 RQ --- 18:139815 01:201047 --:------ 3EF1 002 0000
2021-03-20T22:57:10.587745 074 I --- 04:173127 --:------ 01:201047 2309 003 0206A4
2021-03-20T22:57:11.136195 000 RQ --- 18:139815 01:201047 --:------ 3EF1 002 0000
2021-03-20T22:57:11.589633 058 I --- 04:179866 --:------ 01:201047 2309 003 030834
2021-03-20T22:57:12.590445 092 I --- 04:179995 --:------ 01:201047 2309 003 000834
2021-03-20T22:57:13.639348 000 RQ --- 18:139815 01:201047 --:------ 7FFF 002 0000
2021-03-20T22:57:13.692345 000 RQ --- 18:139815 01:201047 --:------ 0150 002 0000
2021-03-20T22:57:14.091153 090 I --- 04:179995 --:------ 01:201047 1060 003 00FF01
2021-03-20T22:57:14.103178 091 I --- 04:179995 --:------ 04:179995 1060 003 00FF01
2021-03-20T22:57:14.638880 000 RQ --- 18:139815 01:201047 --:------ 0150 002 0000
2021-03-20T22:57:15.686067 000 RQ --- 18:139815 01:201047 --:------ 0150 002 0000
2021-03-20T22:57:16.088845 054 I --- 04:173125 --:------ 01:201047 2309 003 010640
2021-03-20T22:57:18.130527 000 RQ --- 18:139815 01:201047 --:------ 2389 002 0000
2021-03-20T22:57:18.669762 000 RQ --- 18:139815 01:201047 --:------ 2389 002 0000
2021-03-20T22:57:19.713637 000 RQ --- 18:139815 01:201047 --:------ 2389 002 0000
2021-03-20T22:57:21.775957 000 I --- 18:139815 63:262142 --:------ 7FFF 024 00003A15B6ED807F66756C6C207363616E3A20656E646564
HR80ās:
'04:173125',
'04:173127',
'04:173131',
'04:173146',
'04:176841',
'04:177708',
'04:177711',
'04:177712',
'04:177713',
'04:177718',
'04:179866',
'04:179981',
'04:179993',
'04:179995'
Iām on Hometronic and still have problems with my HR80s being all orphans. I remember you saying something about enabling the eavesdropping so if you want me to test it for you Iām happy to do that.
I have also switched my HC60NG for BDR91 today and all of a sudden I seem to have some requests coming from device ID 17
RQ --- 17:000730 01:020766 --:------ 2349 002 0600
RQ --- 17:000730 13:187724 --:------ 3EF1 001 00
Iāll let it run for a day or so and send you the logs if you are interested. I think they also include the binding procedure for BDR91 on Hometronic. It seems to be a bit different to the one on Wiki (very simplistic)
These are corrupt packets.
Yes - Iāll let you know here.
Can you do me a favor & re-bind a few of them please - see what that does to the schema.
Maybe your definition of a one-way binding is different to mine? I know the HM80 binds one-wat (it only receives, it doesnāt send), and the HCW80 is a bit iffy tooā¦
I have a HR80 I can get my hand on, so maybe weāll have to wait for that.
Push comes to shove - Iāll just turn eavesdropping back on in some way.
Iāll give it a go tomorrow! From the packet logs, it looks like the HR92s send and receive (i.e. I see them mostly broadcasting, but occasionally RQāing the controller and receiving a response), the HR80s only send (broadcast onlyt, nothing ever sent back to them.) Maybe it is indeed a binding problemā¦the odd thing is they āworkā - following the schedule, open/close as they should, setpoint updated on the screen (though I wonder how that works if they donāt receiveā¦)
Results are in, binding a DTS92e as zone sensor and an HR80 as TRV to zone 3.
2021-03-21T12:26:07.221729 040 I --- 22:028749 --:------ 22:028749 1FC9 024 00230958704D0030C958704D00000858704D001FC958704D
2021-03-21T12:26:11.150225 034 I --- 01:201047 --:------ 01:201047 1FC9 018 0323090711570330C9071157031FC9071157
2021-03-21T12:26:20.088696 032 I --- 01:201047 --:------ 01:201047 0004 022 03004F66666963657300000000000000000000000000
2021-03-21T12:26:20.094716 032 W --- 01:201047 --:------ 01:201047 1F09 003 F8005F
2021-03-21T12:26:20.106650 032 I --- 01:201047 --:------ 01:201047 2309 003 030834
2021-03-21T12:26:29.800041 032 I --- 01:201047 --:------ 01:201047 1F09 003 FF078F
^^Failed binding, the DTS92e did not sync and then I guess the controller gives up
2021-03-21T12:26:56.166548 037 I --- 22:028749 --:------ 22:028749 1FC9 024 00230958704D0030C958704D00000858704D001FC958704D
2021-03-21T12:26:56.176564 034 W --- 01:201047 22:028749 --:------ 1FC9 006 032309071157
2021-03-21T12:33:26.529020 041 W --- 04:179866 --:------ 01:201047 0001 005 0300000505
2021-03-21T12:33:49.340072 039 I --- 04:179866 63:262142 --:------ 1FC9 006 0030C912BE9A
2021-03-21T12:33:58.212592 035 I --- 01:201047 --:------ 01:201047 1FC9 018 0323090711570330C9071157031FC9071157
2021-03-21T12:34:07.032896 035 I --- 04:179866 --:------ 04:179866 30C9 003 000935
2021-03-21T12:34:07.141884 032 I --- 01:201047 --:------ 01:201047 0004 022 03004F66666963657300000000000000000000000000
2021-03-21T12:34:07.148866 032 W --- 01:201047 --:------ 01:201047 1F09 003 F804CE
2021-03-21T12:34:07.159869 032 I --- 01:201047 --:------ 01:201047 2309 003 030834
^^successful binding, DTS92e and and HR80 synced. Note I had to restart the HR80 to get it into binding mode, i.e. as it boots it goes to sync mode, pressing the recessed button then gets it into bind mode. I suppose the 0001 is the RF check it does as it starts.
The Schema unfortunately does not update. Here is 000C output for zone 3:
13:28:21.758 -> 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0304
13:28:21.758 -> 046 RP --- 01:201047 18:139815 --:------ 000C 006 03040058704D
13:29:26.030 -> 000 RQ --- 18:139815 01:201047 --:------ 000C 002 0308
13:29:26.030 -> 047 RP --- 01:201047 18:139815 --:------ 000C 006 03087FFFFFFF
