Tip: you can make any sensor fakable, even a real/physical device - but if you are using a real device, make sure you turn it off (take it’s batteries out).
The hand-crafted schema should really me minimal - I would limit it to:
controller (always)
OTB (if any, because they can’t be discovered)
older TRVs (HR80s) (because they can’t be discovered)
and non-evohome systems (they won’t support discovery)
Finally a schema can be constructed via discovery (recommended) & eavesdropping (avoid, especially without an allow_list).
What should happen is this:
if restore_state is enabled, and a cached schema exists, use that, otherwise use the hand-crafted schema,
then perform discovery (enabled by default), then eavesdrop (disabled by default)
Discovery is invoked whenever it sees a controller, Eavesdropping occurs whenever it sees a device.
I’ve read it before in this, but it didn’t occur to me that would the easiest solution. Just didn’t think of that. I’ve added this situation to the FAQ on the wiki if you don’t mind.
And I am aware that the faked sensors are very experimental. I don’t mind like to test it, it don’t need heating in that area right now. From october on I need it, if it doesn’t work I have other options to add a sensor :). But I really like the whole evohome_cc/ramses_rf package with all the possibilities out there, being less depended on the cloud for monitoring is already a great advantage.
Thx for the explanation, so in my situation where i have 3 orphans in my cached schema, i can first set in the configuration restore_state: false, reboot home assistant and let it learn with discovery and eavesdropping the schema.
after that i remove in the config restore_state: false (or set restore_state: true but i think it,s the default setting) and restart home assistant.
After this my orphans should be away and my fake sensor will be relearned because the controller thinks it’s a real sensor. Maybe i have to disable my automation that updates my fake sensors temperture until the sensor is releared.
Or is it simpeler to remove the orhans in de cached schema and restart?
change this:
Clearly this is a mess - I will be refactoring it all…
Theory says: if these orphans are now filtered out with an allow/block list, and you wait ‘a while’, then they will definitely end up ‘tombstoning’ and disappearing from your cached schema.
after that, just delete the device from HA entity registry…
If they are not filtered out then they may persist, or - more likely - others may appear.
That would do it, unless they’re still mentioned in the packet list.
They are mentioned in the packet list, i will wait for a while then i have a allow list, we will see if they will dissapear from the schema.
I have them already removed in home assistant that was possible after a while.
The above are simply corrupt packets - ADDR0 is corrupt, although ADDR2 is OK. These packets caused the problem, and the problem is persisting because they are not expiring…
So I will harden this code - expire all packets at max. 1 hour.
@zxdavb Have implemented this RF method for monitoring Evohome. I’ve long been using the official cloud based integration, but very interested in excluding the cloud. I followed the instructions and all works well. Very happy. I have one question.
I have identical radiator valves in different rooms, and one reports an attribute that the other doesn’t. Is there any obvious reason why this should be? I’ve attached the attribute list for the two rads, the difference is the presence of the attribute ‘hvac_action’.
Updated to 0.9.11, so far looking good all entities are available the orhans are removed from the schema.
Only the names of the zones are away on my cards in home assistant, but maybe that has to be relearned.
Just upgraded from 0.9.4 → 0.9.11 myself and spotted this:
If you click on the card, in my case the Simple Thermostat, it shows the name:
If you click on the settings, cog icon, it shows the name greyed out - so seems to be present. If you override that and explicitly populate the box then they show again:
Whenever I leave the restore_state as true, HomeAssistant crashes quickly after boot. Any idea why this is happening @zxdavb ? This has been happening since quite a few versions back now.
2021-06-01 13:27:44 WARNING (MainThread) [ramses_rf.transport] PktProtocolQos.send_data(RQ|02:001107|10E0|00): boff=0, want=RP|02:001107|10E0|00, tout=2021-06-01 13:27:44.608375: EXPIRED (0/0)
2021-06-01 13:29:48 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/config/custom_components/evohome_cc/__init__.py", line 271, in async_update
new_domains = self._get_domains()
File "/config/custom_components/evohome_cc/__init__.py", line 227, in _get_domains
_LOGGER.info("Params = %s", evohome.params)
File "/usr/local/lib/python3.8/site-packages/ramses_rf/systems.py", line 151, in params
params = super().params
File "/usr/local/lib/python3.8/site-packages/ramses_rf/systems.py", line 194, in params
File "/usr/local/lib/python3.8/site-packages/ramses_rf/systems.py", line 576, in params
return {**super().params, ATTR_ZONES: {z.idx: z.params for z in self._zones}}
File "/usr/local/lib/python3.8/site-packages/ramses_rf/systems.py", line 600, in params
ATTR_UFH_SYSTEM: {
File "/usr/local/lib/python3.8/site-packages/ramses_rf/systems.py", line 601, in <dictcomp>
d.id: d.params for d in sorted(self._ctl.devices) if d.type == "02"
File "/usr/local/lib/python3.8/site-packages/ramses_rf/devices.py", line 835, in params
"circuits": self.setpoints,
File "/usr/local/lib/python3.8/site-packages/ramses_rf/devices.py", line 817, in setpoints
for c in self._setpoints.payload
AttributeError: 'NoneType' object has no attribute 'payload'
2021-06-01 13:29:48 ERROR (MainThread) [ramses_rf.message] Message(RP|01:187666|313F|00), received at 2021-06-01 13:24:49.751674: msg has tombstoned (2021-06-01 13:29:48.982111, 0:00:03)
