Honeywell Lyric integration error
Honeywell Lyric integration stpped working.
Error:
Failed setup, will retry: Cannot connect to host api.honeywell.com:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate has expired (_ssl.c:1081)')]
On Honewell Developer website there is this announcement:
IMPORTANT: If your integration is still using the api.honeywell.com domain, please switch to api.honeywellhome.com
Can I do anything, or the integration should be updated?
I would suggest checking if there is a github issue open for this, and if not open one. If there is, add a thumbs up to show you also need an answer.
Solved by latest Core update, 2026.5.4
Mine also solved.
