Honeywell Lyric Official Integration OAuth problems
I’m having problems authenticating to the Honeywell Development site using the HA Configure button on the integration. I’m confused about what to use for the OAuth Client ID and the OAuth Client Secret.
The new Application I created on the Honeywell website gives me a Consumer Key and a Consumer Secret. I have tried using them on HA. But I keep getting the message: "{“code”:401, “message”:“Invalid client_id”}.
Could someone please clarify if I’m doing it correctly, or do I need to use some other info. Thanks.
OAuth Client ID = Consumer Key
OAuth Client Secret = Consumer Secret.
Please copy/paste it carefully. All characters and no leading or trailing spaces!
Thank you.
I have the same problem. The first time when I wanted to import the Lyric integration I entered the wrong Id. Now, when I want to import the Lyric integration I get : * code: 401,* message: "Invalid client_id"
Can someone help me ?
You could try deleting the credentials stored by Home Assistant. I had to do that to be able to enter new credentials.
On the integrations page, click the 3 dots on the top, then Application Credentials, then select the credential used by Lyric and delete it.
