I configure the Honeywell total connect alarm via the UI and al works fine. Entities are discovered, tha alarm panel is available and all is good. Once I reboot the alarm panel is lo longer accessible even the configuration is still present in the UI. I need to delete the integration it and re-add the Honeywell integration in the UI for it to work. Only till the next reboot where it will no longer work again. Any thoughts on what might be causing this?
