saboaua
(Patrick)
May 17, 2019, 10:47pm
1
I added the components to my home assistant as mentioned. I got the entities, but the entity for disarming the alarm when armed is not working.
I noticed when arming on lovelace card, it takes like 2 click on the arm button and once armed it won’t disarmed with the disarmed button.
Any suggestion what may be causing this?
Home Assistant Version 0.93.1
Honeywell Vista 20P
Envisalink 3
GaryK
(Gary Kelley)
May 17, 2019, 11:47pm
2
Have alarm_code
configured? Of course you did.
saboaua
(Patrick)
May 18, 2019, 12:47am
3
Yes, the alarm code is configured. Like a mention i need to double click the arm button for it to arm, but cannot disarm it form the card.
Also created an automation and doesn’t disarm the alarm when entering the home zone.
#Envisalink
envisalink:
host: !secret envisahost
panel_type: HONEYWELL
user_name: !secret honeyusern
password: !secret honeypassw
code: !secret honeycode
port: 4025
evl_version: 3
keepalive_interval: 60
zonedump_interval: 30
timeout: 10
panic_type: Police
zones:
2:
name: ‘Main Entrance’
type: ‘opening’
3:
type: ‘opening’
4:
name: ‘Master Bedroom French Door’
type: ‘opening’
partitions:
1:
GaryK
(Gary Kelley)
May 18, 2019, 11:03am
4
Without formatting I can’t verify spacing, but content seems correct. I have a version 4 card. Not having any problems.
saboaua
(Patrick)
May 18, 2019, 11:34am
5
it connects to the envisalink, but the disarm doesn’t function and i noticed i need to double click on the card for it to armed the system in lovelace.
GaryK
(Gary Kelley)
May 18, 2019, 11:50am
6
Looks good. Have you tried increasing the timeout value? I don’t have timeout set in my config.
saboaua
(Patrick)
May 18, 2019, 12:04pm
7
i will remove it and restart the HA and will check if it makes any difference.
saboaua
(Patrick)
May 18, 2019, 12:31pm
8
Remain the same, won’t disarm from card and have to use envisalink self to disarm the alarm.
The arm also does happen with 1 click, have to click twice on arm for the command to be send to arm the alarm.
GaryK
(Gary Kelley)
May 18, 2019, 2:56pm
9
I have no other suggestions. Perhaps this is a bug in the component. Have you searched Github for similar issues?
saboaua
(Patrick)
May 18, 2019, 4:10pm
10
I found the error, as the it was simply the user code was incorrectly and now working fine.
Thanks for the help
GaryK
(Gary Kelley)
May 18, 2019, 4:36pm
11
It happens quite a bit. Glad you’re up and running.
saboaua
(Patrick)
May 20, 2019, 3:42pm
12
yes, now i have figure put the condition part to work. When entering zone home, to turn off the alarm, but only if the alarm is armed.
GaryK
(Gary Kelley)
May 20, 2019, 3:46pm
13
This is the action I use:
- data:
entity_id: alarm_control_panel.alarm
service: alarm_control_panel.alarm_disarm
You don’t need the alarm status condition. A disarm action won’t effect an already disarmed alarm.
saboaua
(Patrick)
May 20, 2019, 3:51pm
14
ok, I have it running when entering home will disarm the alarm. Thanks for the reply and will leave it without the condition part.
