Hooking into Assist timers
I was trying to setup an automation to alert house-wide when an assist- timer expires, but i cant find any trace of a timer set via assist.
Any tipps?
Add any helper component (e.g momentary switch) in esphome code that will change the value during on_timer_started and use it in HA.
Sounds good! BUT HOW?? :smiley:
Can you provide instructions for this? I have no idea what you mean with “esphome code”
What are you using to set those timers?
“Hey Jarvis, set a timer for the pasta, 7 minutes”
No, not what you are saying!
Which device do you speak to?
https://voice-pe.home-assistant.io/documentation/about_home-assistant_voice_preview_edition/
OK, the HA voice PE is using/configured with ESPHome to connect to HA.
What @mchk is implying: you have to edit the config of the VPE.
This seems far beyond my skills… :frowning:
ATM, timers are quite new, as is the VPE, and the devs are thinking about how to bring them more to the surface so I guess in the coming releases, this will be improved.
