Hosts file for google calendar component
One of the main things I need to get HA to do is read my google calendar. So looking at the Node-Red Google node.
It rightfully has found that the RPI its running on is a private network and its says I have to edit the host file.
However is the host file the one on Resin or in the node-red to container?
Found it. Its the Hosts file on the pc you are using to set it up…
Got as far as getting it to autorise and now getting a auth worked but profile fetching failed error but I dont think its related to the host file. Going off to do a bit of a search.
Managed to fix this? Got this for a few days now… Really annoying.
