I set this up yesterday and am quite pleased with it: An at-a-glance component for Lovelace that shows you some key stats about the current state of the house:
This is the number of windows open, number of (exterior) doors open, number of lights on, and number of people home. These are clickable to bring up the standard state history for each item.
How it works:
Start by ensuring that all the appropriate sensors have the right
device_class
And override it where necessary using Configuration > Customisations > [choose entity] > [edit device_class] > Save. Windows and doors are all contact sensors and by default it seemed were getting a mix of ‘opening’ and ‘door’ classes. I set them all to ‘window’ or ‘door’ as appropriate. -
Create template sensors for the counts
Add the following to configuration.yaml:sensor: - platform: template sensors: windows_open_count: friendly_name: Number of windows open icon_template: mdi:window-open value_template: >- {{ states.binary_sensor | selectattr('attributes.device_class', 'eq', 'window') | selectattr('state', 'eq', 'on') | list | length }} doors_open_count: friendly_name: Number of doors open icon_template: mdi:door-open value_template: >- {{ states.binary_sensor | selectattr('attributes.device_class', 'eq', 'door') | selectattr('state', 'eq', 'on') | list | length }} lights_on_count: friendly_name: Number of lights on icon_template: mdi:lightbulb-on-outline value_template: >- {{ states.light | selectattr('state', 'eq', 'on') | list | length }} people_home_count: friendly_name: Number of people at home icon_template: mdi:account-multiple value_template: >- {{ states.person | selectattr('state', 'eq', 'home') | list | length }}
Add lovelace cards
I’m using the standard horizontal stack, with the custom button card, which can be installed via HACS. As an easy way to do this, choose ‘Edit dashboard’ from the Lovelace view that you want to add the card to, then click the ‘Add card’ button, choose ‘Manual’ (the bottom option), and then replace the default code in the editor with this:type: horizontal-stack cards: - type: custom:button-card entity: sensor.windows_open_count size: 25px show_name: false show_state: true layout: icon_state aspect_ratio: 2/1 - type: custom:button-card entity: sensor.doors_open_count size: 25px show_name: false show_state: true layout: icon_state aspect_ratio: 2/1 - type: custom:button-card entity: sensor.lights_on_count size: 25px show_name: false show_state: true layout: icon_state aspect_ratio: 2/1 - type: custom:button-card entity: sensor.people_home_count size: 25px show_name: false show_state: true layout: icon_state aspect_ratio: 2/1
What’s really nice about this vs other solutions I’ve seen discussed is:
- It adapts as you add and remove sensors to your home, so you don’t need to maintain a manual list of entities.
- It’s instantly updated - rather than requiring an automation to trigger to update a stored
input_number
- By using a standard Lovelace component it means that you get all the interactivity that comes with that, like the state history on click etc.
Things I would like to improve:
- When you tap/click the buttons, rather than (or in addition to) telling me how the rolled-up value has changed over time, it would be useful to see a list of the entities that are in that count, eg I press the ‘people’ button and it tells me who is at home, as well as when the number of people at home changed.
