HouSign — Gesture Control for Home Assistant
Download - HouSign-Setup.exe
Control your smart home with hand gestures. No buttons, no voice, no phone — just a wave.
HouSign watches your camera in the background, detects hand gestures using MediaPipe, and fires actions in Home Assistant the moment it recognizes what you’re doing.
See it in action
What it does
- Runs quietly in the system tray — starts with Windows, stays out of your way
- Uses your webcam to track hand gestures in real time
- Sends commands to Home Assistant via WebSocket (lights, media players, scenes, scripts — anything)
- Supports an activation gesture (like a wake word, but for your hands) so it only listens when you want it to
- Plays sound feedback so you know when it picked up your gesture
- Comes with a clean settings UI to configure everything without touching JSON
Getting started
Option 1 — Windows installer (recommended)
Download HouSign-Setup.exe from Releases, run it, enter your Home Assistant URL and token, done.
The installer handles everything — shortcuts, autostart option, default config.
Option 2 — Run from source
git clone https://github.com/SmolinskiP/HouSign
cd HouSign
python -m venv venv
venv\Scripts\python.exe -m pip install -r requirements.txt
python ha_gestures/app.py
Requires Python 3.11.
Configuration
On first run, open Settings from the tray menu and fill in:
- Home Assistant URL — e.g.
http://homeassistant.local:8123/ - Long-Lived Access Token — create one in HA under Profile → Security → Long-Lived Access Tokens
Activation gesture
By default, HouSign uses an activation mode — it won’t fire commands until you make a specific pose (like an open palm held for ~600ms). This prevents accidental triggers while you’re just moving around. You can disable it and go always-listening if you prefer.
How gesture bindings work
Each binding connects a gesture to a Home Assistant action:
| Field | Example |
| Gesture | open_palm |
| Mode | one_hand |
| Action type | service |
| Domain | light |
| Service | turn_off |
| Entity | light.living_room |
Execution modes:
- instant — fires once, immediately ends the session
- hold & repeat — keeps firing while you hold the gesture (great for dimming)
System tray
The tray icon shows the current runtime state and lets you open settings, start a preview, reload config, or quit.
Requirements
- Windows 10/11 (64-bit)
- Webcam
- Home Assistant instance reachable on your local network
Built with
- MediaPipe — hand tracking
- Flet — settings UI
- pystray — system tray
- PyAudio — sound feedback
- PyInstaller — Windows packaging
