How can I change wrong data from a helper
Hello, I wanted to track my total energy consumption. But since I’ve had problems with the standard energy tracker being reset randomly I settled for a helper that sums up every power-meter and then an integral sensor to give me a reading in kWh.
I screwed up something, I don’t quite know what but my sensor jumped from 50,875 kWh to 50.875 kWh (I’m using , for decimals so it went to 50k kwh)
I’ve tried “dev settings → statistics” but when I select my sensor I can’t find the data that created this problem.
Is there any other way to fix this?
Not even using the “Outliers” button?
Nope, that data is nowhere to be found. I dont even quite know how I managed to do that… it literally just switched the , to a .
In your profile (circle icon with initials bottom of the left hand menu) what is this set to:
Its set to auto. I’ve set it to 1.234.567,89 now, but that wont change the data thats already wrong…
You will have to delete it in Developer Tools → Statistics.
the full data? I would like not to do that xD
Is there any way to recreate the helper with a starting value of whatever it is now?
Because after that data error it seems to behave normally again
You can delete the sensor. Then wait until there is a FIX ISSUE button in Dev Tools Statistics that will ask you to delete the statistics as the sensor no longer exists. Then recreate it.
