How can I configure deadman functionality on Fronius Gen24 inverter using modbus
Hi, since I’m new in this community I’m not sure if this is the right place to ask for support.
However:
We have a Fronius Primo Gen24 Plus 10kw inverter and a BYD battery. We live in New Zealand and our electricity provider has peak tariffs (07:00 to 9:00 and 17:00 to 21:00) for both use and buyback and an hour of free power per day outside of peak times – our free hour is set to 6:00 to 7:00.
We have very successfully implemented redpomodoro fronius_modbus (int +sf) and solcast and the system has been running for 12 months now. I force charge during the free hour and then may or may not force discharge during peak export tariffs dependent on solcast forecast , battery soc and load expectations.
I would like to implement deadman functionality so that if power or network fails while I’m up a mountain and the inverter is in a force charge or force discharge state, I want the inverter to revert to auto mode.
I tested the code below which I got from google expecting the timer to count down, but it immediately reverted.
I’d love to hear from anyone who has found a way to implement deadman restoration to auto battery storage mode using modbus on the gen24 plus inverter?
Thanks you for reading this.
Cheers Noel
import time
from pymodbus.client import ModbusTcpClient
--- LOCAL ROUTING CONFIGURATION ---
INVERTER_IP = "192.168.1.1"
PORT = 502
SLAVE_ID = 1
client = ModbusTcpClient(INVERTER_IP, port=PORT)
if client.connect():
print("=" * 70)
print(" AUTONOMOUS MOUNTAIN WATCHDOG: Activating 30s Hardware Lease Timer")
print("=" * 70)
# Write a 30-second countdown window to register 40348 instead of a static mode flag
print("Sending 30-second hardware safety window to register 40348...")
client.write_register(40348, 30, slave=SLAVE_ID)
time.sleep(0.1)
print("Hardware safety window sent. Monitoring the countdown loop live below...\n")
print("Simulate a failure now: Disconnect your Pi or stop your scripts.\n")
try:
    for i in range(35):
        # Poll register 40348 to watch the hardware clock tick down to zero
        res_m = client.read_holding_registers(40348, 1, slave=SLAVE_ID)
        m_val = res_m.registers[0] if not res_m.isError() else "ERR"
        print(f"[{time.strftime('%H:%M:%S')}] Inverter Safety Clock (40348): {m_val}s remaining")
        # If it snaps back to 100 or 0, the timeout has triggered successfully
        if m_val == 100 or m_val == 0:
            print("\n🎉 SUCCESS: The hardware timer hit zero!")
            print("The inverter automatically wiped the overrides and snapped back to AUTO natively!")
            break
        time.sleep(1)
except KeyboardInterrupt:
    pass
finally:
    client.close()
else:
print("Connection failed.")
Perhaps you must play with 40358 InOutWRte_RvtTms
Google AI mentions it's not support while the fronius modbus documents tell it's supported, at leat for the Gen24Plus 10.0
This defines a period (seconds) until the manually set inWRte && outWRte values will get restored by ther defaults. What's not mention is if this also affects storctl_mod and if that works no matter which value storctl_mod got.
Haven't found more information but I didn't start digging a lot. Normally I'd say storctl_mod setting won't matter since if inWRte and outWRte is set to their defaults (100%) any storctl_mod value would have no effect at all.
From theory I'd say if you set the RvtTms to 5mins for example renewing this each time these minutes nearly passed by it'll ensure to keep the defined inWRte && outWRte until something failed and the RvtTms timer reached it's end.
But I never tried that myself if it works like this.
