Hello. I have a 3 year old HA Yellow with a CM4 (which has emcc) and NVME, I think I pushed the core os to the NVME during initial setup (but not sure). Is there a way to determine this on an existing install??
The HA data is 100% on the NVME!
If I gained DIRECT ACCESS to the HAOS via port 22222 would the lsblk command’s output be conclusing as to the HAOS real location?
Hopefully there is a simpler way.
Thanks in advance, Mac
Did i ask this question in a bad way? Have I offended the community? I dont think this is simple? I’ve read and searched for hours with nothing.
Is the question unclear – I cant believe the answer is beyond this group.
Solved - The brute force way. I grabbed a CM5 (which has EMcc but unprogrammed). I then swapped it for the CM4 that was installed. I would not Boot. So ended up upgrading the hard way. BTW, I did force the HAOS onto the NVME this time.
Sorry, apparently then is no way to check without physical intervention.
