I have a sensor called sensor.smart_meter_electricity_import_unit_rate.
I wish to create a query that will print out the state and last changed/updated as far back as possible.
I have very little SQL programming experience and trying to work out which tables I need to look in, is defeating me!
Regards, Martin
The database schema changes occasionally, so if you’re using old posts for inspiration, prepare for disappointment.
Thanks for the warning!
This is the query that I working with so far:
SELECT state, DATETIME(last_updated_ts, 'auto')
FROM "states"
WHERE "metadata_id" = (select metadata_id from states_meta where entity_id = 'sensor.smart_meter_electricity_import_unit_rate')
ORDER BY DATETIME(last_updated_ts, 'auto')
Any suggestions on why it only gives results back to the beginning of the month?
Regards, M.
10 days default storage.
