Hello.
Thanks to the help of this forum, I have been able to configure a e-ink device from lilygo.
It is battery powered, so I try to make it as efficient as possible. The way I do it is using lambdas, and as soon as everything has been updated it goes to sleep for a minute.
This mostly works, and the device has been running for about 2 weeks now. However, I’m getting a lot of error logs about the screen not updating properly, and that is noticeable in the screen state. Sometimes it looks correct after an update, sometimes it shows artifacts (partially erased numbers, or extra black areas).
I suspect that my code to detect when the screen has completed the udpate is not correct, so if someone can help me figure out why or fix it that will be awesome.
Here is the device configuration (esphome):
# https://gist.github.com/dedalodaelus/159b73a036c250267d0dbbf496eb96f6
substitutions:
devicename: esphome-web-663194
friendly_name: E-ink esphome
sleep_time: 2min
wifi_signal_update: 60s
uptime_update: 60s
globals:
- id: uptime_saved
type: time_t
initial_value: "0"
restore_value: yes
- id: ts_saved
type: time_t
initial_value: "0"
restore_value: yes
- id: wifi_signal_sent
type: bool
initial_value: "false"
restore_value: no
- id: uptime_sent
type: bool
restore_value: no
- id: tsync_read
type: bool
esphome:
on_boot:
then:
- deep_sleep.prevent: deep_sleep_control
on_shutdown:
then:
- lambda: |-
id(ts_saved) = id(homeassistant_time).now().timestamp;
esp32:
board: esp32dev
framework:
type: arduino
logger:
api:
ota:
wifi:
ssid: !secret wifi_ssid
fast_connect: true
power_save_mode: HIGH
manual_ip:
static_ip: 192.168.0.40
gateway: 192.168.0.1
subnet: 255.255.255.0
ap:
ssid: "Esphome-Web-663194"
password: "blablabla"
captive_portal:
deep_sleep:
# run_duration: 2min # automatically optimized by script
sleep_duration: $sleep_time
esp32_ext1_wakeup:
pins: GPIO39 #This is the same as button 1 on the 4.7" T5 board; they have button 2 tied to GPIO 34 and button 3 tied to GPIO 35, but GPIO 35 on this board is (I think) the battery voltage, so these are likely different.
mode: ALL_LOW
spi:
clk_pin: 18
mosi_pin: 23
time:
- platform: homeassistant
on_time_sync:
then:
- script.execute: calculate_uptime
binary_sensor:
name: $friendly_name Prevent Deep Sleep
entity_id: input_boolean.e_ink_prevent_deep_sleep
on_state:
then:
- script.execute: consider_deep_sleep
- platform: status
text_sensor:
name: $friendly_name Uptime Human Readable
icon: mdi:clock-start
- platform: wifi_signal
name: $friendly_name WiFi Signal
on_value:
then:
- lambda: |-
id(wifi_signal_sent) = true;
update_interval: $wifi_signal_update
entity_id: sensor.mijia_temperature
on_value:
script.execute: update_screen
entity_id: sensor.mj_salon_temp
on_value:
- platform: uptime
update_interval: $uptime_update
filters:
- lambda: |-
if (
!id(homeassistant_time).now().is_valid()
!id(tsync_read)
ESP_LOGD("uptime", "time-not-valid");
return id(uptime_sensor).raw_state;
time_t time_now = id(homeassistant_time).now().timestamp;
// ESP_LOGD("uptime", "prev ts %d", id(ts_saved));
time_t uptime_delta = time_now-id(ts_saved);
ESP_LOGD("uptime", "uptime delta: %d", uptime_delta);
id(uptime_saved)+=uptime_delta;
if (id(uptime_saved)<0)
ESP_LOGD("uptime", "Something went wrong negative uptime");
id(uptime_saved)=0;
id(ts_saved) = time_now;
// ESP_LOGD("uptime", "time now %d", time_now);
id(uptime_sent) = true;
return id(uptime_saved);
font:
- file: 'slkscr.ttf'
- file: 'BebasNeue-Regular.ttf'
- file: 'arial.ttf'
display:
- platform: waveshare_epaper
# Remove the # in front of one of the model lines below
model: 2.90inv2
#model: 2.13in-ttgo
#model: 2.13in-ttgo-b73
cs_pin: 5
dc_pin: 17
busy_pin: 4
reset_pin: 16
update_interval: 1min
# If everything works, try to set full_update_every to 30 or 60
full_update_every: 5
rotation: 90
lambda: |-
it.printf(0, 5, id(bigfont), TextAlign::TOP_LEFT, "Office");
if (id(office_temp).has_state())
it.printf(0, 25, id(font1), TextAlign::TOP_LEFT, "%.1fC", id(office_temp).state);
else
ESP_LOGD("screen", "No data from HA for office_temp");
it.strftime(200, 25, id(font1), TextAlign::TOP_RIGHT, "%H:%M", id(homeassistant_time).now());
it.printf(240, 25, id(font1), TextAlign::TOP_RIGHT, "%s", id(uptime_eink_human).state.c_str());
it.line(0, 40, 300, 40);
it.printf(0, 45, id(bigfont), TextAlign::TOP_LEFT, "SALON");
if (id(salon_temp).has_state())
it.printf(140, 45, id(font1), TextAlign::TOP_RIGHT, "%.1f°C", id(salon_temp).state);
id(consider_deep_sleep).execute();
script:
- id: update_screen
mode: restart
then:
- if:
condition:
lambda: |-
return id(office_temp).has_state() && id(salon_temp).has_state();
then:
component.update: eink_display
- id: calculate_uptime
mode: queued
then:
- if:
condition:
time.has_time:
then:
- logger.log: "Saving timestamp"
- lambda: |-
id(tsync_read) = true;
- id: consider_deep_sleep
mode: queued
then:
- logger.log: "Considering Deep Sleep"
- delay: 5s
- if:
condition:
and:
- wifi.connected
- api.connected
- binary_sensor.is_off: prevent_deep_sleep
- lambda: |-
if (
id(uptime_sent) &&
ESP_LOGD("sensors", "All sensors data sent");
return true;
return false;
then:
- logger.log: "Entering in Deep Sleep"
- deep_sleep.enter: deep_sleep_control
else:
- logger.log: "Skipping Deep Sleep"
- delay: 1s
