How can I install the xiaomi_miio.py to integrate xiaomi vacuum cleaner?
Hi, I have an existential doubt. I have read a lot but I can not find exactly how to do it.
In Hassbian, what commands should be used? Where are the .py copied? Do I just need xiaomi_miio.py or someone else? Do you have to install it in a virtual environment? The truth is that I’m not clear, or I’m very clumsy …: S
https://github.com/home-assistant/home-assistant/blob/dev/homeassistant/components/vacuum/xiaomi_miio.py
Can you recommend another way to configure the xiaomi vacuum? To get all the available options:
Can someone please help me? I’d be really grateful.
There are issues with Xiaomi Miio and Home assistant 62.0 and 62.1. I (and several others) had it working with earlier versions of Home assistant.
You should following the instructions on the components page: https://home-assistant.io/components/vacuum.xiaomi_miio/
  • but it will proberly not work with 62.0 or 62.1.
There is an issue on the official GitHub and it seams like there is and fix coming
