I’ve got a legacy alarm system connected in parallel to a Konnected Alarm Panel Pro. “In parallel,” means that the legacy keypads are still on the wall and can be used to enable or disable the alarm. The Konnected component allows me to connect the alarm to HA so I can arm/disarm and see the status of each sensor.
Using Manual Alarm Control Panel (MACP), I am able to arm and disarm my alarm without issue. Unfortunately, the state of the alarm (arm/home, arm/away, etc.) does not sync with HA if someone used the legacy keypad to do something with the alarm.
A scenario:
- Person A uses the keypad to arm/away
- Person B can look in HA at the Konnected integration and see the Armed/Disarmed binary sensor (output_17) status is open (meaning the alarm is armed), but it doesn’t specify whether it is armed in home or away mode
- MACP still shows a status of disabled
I can’t figure out the Action portion of the automation where I tell MACP to sync the Arm/Away status. I’m only seeing options that would tell MACP to execute the command for Arm/Away, which would then disable the alarm, or to confirm a status.
I need to change the status.
Here is the yaml for the automation. It references two different automations that I used to have MACP tell Konnected to arm the system.
alias: Arm/Away or Alarm/Stay Enabled from Keypad
description: When the alarm is enabled without HA
- platform: state
entity_id:
- binary_sensor.output_17
to: "on"
condition:
- condition: not
conditions:
- condition: state
entity_id: automation.arme_away_enabled_by_manual_alarm_control_panel
state: "off"
- condition: not
conditions:
- condition: state
entity_id: automation.home_stay_enabled_from_manual_alarm_control_panel
state: "off"
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- if:
- condition: and
conditions:
- condition: state
entity_id: binary_sensor.back_door
state: "off"
for:
hours: 0
minutes: 1
seconds: 0
- condition: state
entity_id: binary_sensor.front_door
state: "off"
for:
hours: 0
minutes: 1
seconds: 0
- condition: state
entity_id: binary_sensor.kitchen_entry_door
state: "off"
for:
hours: 0
minutes: 1
seconds: 0
then:
- condition: state
entity_id: alarm_control_panel.home_alarm
state: armed_home
else:
- condition: state
state: armed_away
mode: single
Does anyone have suggestions for the “then” and “else” portions? Thanks!
