bluehj
(bluehj)
August 5, 2021, 8:13am
1
hi,
I can use CURL output as the correct JSON result
curl 'http://192.168.1.11/ajax/fetch.php' \
-H 'Cookie: PHPSESSID=gt5ffbsd8d645jghj456' \
--data-raw 'selected_method=list_devices&selected_group=Devices&selected_output_method=json'
Now I want to use RESTful Sensor to apply to HA:
- platform: rest
resource: http://192.168.1.11/ajax/fetch.php
json_attributes_path: "$.data.0"
value_template: "OK"
json_attributes:
- "state"
verify_ssl: false
headers:
Cookies: PHPSESSID=gt5ffbsd8d645jghj456
data-raw: selected_method=list_devices&selected_group=Devices&selected_output_method=json
this is not working.I don’t see any json results in the properties of sensor.device_list. I make sure that the “headers” part is not written correctly, caused the JSON output to be incorrect. what should be the correct way to write it?
BTW: if I use Command line Sensor to do this,I know how to do and successful testing.
thanks
koying
(Chris B)
August 5, 2021, 8:48am
2
Curl’s “data-raw” is used to send the data body for a PUT or POST method, normally
By default, curl is using GET, and a GET does not have a data body.
Not sure what curl is actually doing here, you might add “-v” to have the details.
Anyway, adding “data-raw” to the headers is wrong.
bluehj
(bluehj)
August 5, 2021, 9:21am
3
and
curl -X POST 'http://192.168.1.11/ajax/fetch.php' \
The results are all correct for the JSON content I want.
is there any way to handle body data in “platform: rest” ? What parameter should be used?
koying
(Chris B)
August 5, 2021, 9:26am
4
Would be:
- platform: rest
method: POST
payload: "selected_method=list_devices&selected_group=Devices&selected_output_method=json"
json_attributes:
- "state"
verify_ssl: false
headers:
bluehj
(bluehj)
August 5, 2021, 11:10am
5
Unfortunately, it doesn’t work
I think maybe the problem is the way it is handled here
