I’m currently trying to set up a twice daily weather report, the one I get from get_weather is not what I want. I need two daytime values but the integration gives me midnight and noon.
So, I set up a API sensor to get the data myself and I get the data.
Now I want to get lets say the average wind speed. And currently this kind of works.
{% for d in range(1,5) %}
{{ state_attr('sensor.smhi_hourly_2', 'timeSeries')
| selectattr('time', '>=', (utcnow().replace(hour=6)+ timedelta(days= d | int)).isoformat())
| selectattr('time', '<=', (utcnow().replace(hour=12)+ timedelta(days= d | int)).isoformat())
| map(attribute='data')| map(attribute='wind_speed')
| list | average | round(1)}} m/s
| selectattr('time', '>=', (utcnow().replace(hour=12)+ timedelta(days= d | int)).isoformat())
| selectattr('time', '<=', (utcnow().replace(hour=18)+ timedelta(days= d | int)).isoformat())
| list | average | round(1) }} m/s
__________________
{% endfor %}
As far as I can tell since the data is in UTC everything is off from what I expect.
I could change the replace but that will mean I get issues at winter time again (right?).
So what would be the “proper solution”?
In case anyone wants to play with the data then the below is the relevant parts of the API output and adjusted templates to just copy paste to template tools.
Summary
{% set json = {
"timeSeries": [
{ "time": "2026-04-07T08:00:00Z", "data": { "wind_speed": 4.8 } },
{ "time": "2026-04-07T09:00:00Z", "data": { "wind_speed": 5.1 } },
{ "time": "2026-04-07T10:00:00Z", "data": { "wind_speed": 5.8 } },
{ "time": "2026-04-07T11:00:00Z", "data": { "wind_speed": 6.3 } },
{ "time": "2026-04-07T12:00:00Z", "data": { "wind_speed": 6.7 } },
{ "time": "2026-04-07T13:00:00Z", "data": { "wind_speed": 7.0 } },
{ "time": "2026-04-07T14:00:00Z", "data": { "wind_speed": 6.4 } },
{ "time": "2026-04-07T15:00:00Z", "data": { "wind_speed": 6.1 } },
{ "time": "2026-04-07T16:00:00Z", "data": { "wind_speed": 6.0 } },
{ "time": "2026-04-07T17:00:00Z", "data": { "wind_speed": 5.7 } },
{ "time": "2026-04-07T18:00:00Z", "data": { "wind_speed": 4.1 } },
{ "time": "2026-04-07T19:00:00Z", "data": { "wind_speed": 2.9 } },
{ "time": "2026-04-07T20:00:00Z", "data": { "wind_speed": 2.4 } },
{ "time": "2026-04-07T21:00:00Z", "data": { "wind_speed": 2.1 } },
{ "time": "2026-04-07T22:00:00Z", "data": { "wind_speed": 2.2 } },
{ "time": "2026-04-07T23:00:00Z", "data": { "wind_speed": 2.1 } },
{ "time": "2026-04-08T00:00:00Z", "data": { "wind_speed": 2.1 } },
{ "time": "2026-04-08T01:00:00Z", "data": { "wind_speed": 2.0 } },
{ "time": "2026-04-08T02:00:00Z", "data": { "wind_speed": 2.1 } },
{ "time": "2026-04-08T03:00:00Z", "data": { "wind_speed": 2.4 } },
{ "time": "2026-04-08T04:00:00Z", "data": { "wind_speed": 2.4 } },
{ "time": "2026-04-08T05:00:00Z", "data": { "wind_speed": 2.4 } },
{ "time": "2026-04-08T06:00:00Z", "data": { "wind_speed": 1.6 } },
{ "time": "2026-04-08T07:00:00Z", "data": { "wind_speed": 2.3 } },
{ "time": "2026-04-08T08:00:00Z", "data": { "wind_speed": 3.4 } },
{ "time": "2026-04-08T09:00:00Z", "data": { "wind_speed": 3.6 } },
{ "time": "2026-04-08T10:00:00Z", "data": { "wind_speed": 3.7 } },
{ "time": "2026-04-08T11:00:00Z", "data": { "wind_speed": 4.4 } },
{ "time": "2026-04-08T12:00:00Z", "data": { "wind_speed": 3.5 } },
{ "time": "2026-04-08T13:00:00Z", "data": { "wind_speed": 2.8 } },
{ "time": "2026-04-08T14:00:00Z", "data": { "wind_speed": 2.4 } },
{ "time": "2026-04-08T15:00:00Z", "data": { "wind_speed": 1.7 } },
{ "time": "2026-04-08T16:00:00Z", "data": { "wind_speed": 0.5 } },
{ "time": "2026-04-08T17:00:00Z", "data": { "wind_speed": 3.2 } },
{ "time": "2026-04-08T18:00:00Z", "data": { "wind_speed": 2.4 } },
{ "time": "2026-04-08T19:00:00Z", "data": { "wind_speed": 2.6 } },
{ "time": "2026-04-08T20:00:00Z", "data": { "wind_speed": 2.4 } },
{ "time": "2026-04-08T21:00:00Z", "data": { "wind_speed": 1.6 } },
{ "time": "2026-04-08T22:00:00Z", "data": { "wind_speed": 1.7 } },
{ "time": "2026-04-08T23:00:00Z", "data": { "wind_speed": 2.1 } },
{ "time": "2026-04-09T00:00:00Z", "data": { "wind_speed": 2.1 } },
{ "time": "2026-04-09T01:00:00Z", "data": { "wind_speed": 0.6 } },
{ "time": "2026-04-09T02:00:00Z", "data": { "wind_speed": 1.2 } },
{ "time": "2026-04-09T03:00:00Z", "data": { "wind_speed": 1.7 } },
{ "time": "2026-04-09T04:00:00Z", "data": { "wind_speed": 2.2 } },
{ "time": "2026-04-09T05:00:00Z", "data": { "wind_speed": 1.9 } },
{ "time": "2026-04-09T06:00:00Z", "data": { "wind_speed": 2.5 } },
{ "time": "2026-04-09T07:00:00Z", "data": { "wind_speed": 2.9 } },
{ "time": "2026-04-09T08:00:00Z", "data": { "wind_speed": 3.6 } },
{ "time": "2026-04-09T09:00:00Z", "data": { "wind_speed": 3.7 } },
{ "time": "2026-04-09T10:00:00Z", "data": { "wind_speed": 4.4 } },
{ "time": "2026-04-09T11:00:00Z", "data": { "wind_speed": 4.7 } },
{ "time": "2026-04-09T12:00:00Z", "data": { "wind_speed": 4.7 } },
{ "time": "2026-04-09T13:00:00Z", "data": { "wind_speed": 4.6 } },
{ "time": "2026-04-09T14:00:00Z", "data": { "wind_speed": 4.8 } },
{ "time": "2026-04-09T15:00:00Z", "data": { "wind_speed": 4.9 } },
{ "time": "2026-04-09T16:00:00Z", "data": { "wind_speed": 5.1 } },
{ "time": "2026-04-10T00:00:00Z", "data": { "wind_speed": 4.9 } },
{ "time": "2026-04-10T06:00:00Z", "data": { "wind_speed": 4.0 } },
{ "time": "2026-04-10T12:00:00Z", "data": { "wind_speed": 5.2 } },
{ "time": "2026-04-10T18:00:00Z", "data": { "wind_speed": 2.2 } },
{ "time": "2026-04-11T00:00:00Z", "data": { "wind_speed": 2.5 } },
{ "time": "2026-04-11T06:00:00Z", "data": { "wind_speed": 3.6 } },
{ "time": "2026-04-11T12:00:00Z", "data": { "wind_speed": 5.1 } },
{ "time": "2026-04-11T18:00:00Z", "data": { "wind_speed": 4.3 } },
{ "time": "2026-04-12T00:00:00Z", "data": { "wind_speed": 4.5 } },
{ "time": "2026-04-12T06:00:00Z", "data": { "wind_speed": 4.3 } },
{ "time": "2026-04-12T12:00:00Z", "data": { "wind_speed": 7.1 } },
{ "time": "2026-04-12T18:00:00Z", "data": { "wind_speed": 5.5 } },
{ "time": "2026-04-13T00:00:00Z", "data": { "wind_speed": 4.7 } },
{ "time": "2026-04-13T12:00:00Z", "data": { "wind_speed": 5.5 } },
{ "time": "2026-04-14T00:00:00Z", "data": { "wind_speed": 4.4 } },
{ "time": "2026-04-14T12:00:00Z", "data": { "wind_speed": 4.9 } },
{ "time": "2026-04-15T00:00:00Z", "data": { "wind_speed": 3.4 } },
{ "time": "2026-04-15T12:00:00Z", "data": { "wind_speed": 4.0 } },
{ "time": "2026-04-16T00:00:00Z", "data": { "wind_speed": 2.9 } },
{ "time": "2026-04-16T12:00:00Z", "data": { "wind_speed": 4.0 } },
{ "time": "2026-04-17T00:00:00Z", "data": { "wind_speed": 2.9 } },
{ "time": "2026-04-17T12:00:00Z", "data": { "wind_speed": 4.1 } }
{{ json.timeSeries
{{ json.timeSeries
__________________
{% endfor %}
