The automation engine looks at your automation triggers, then sets up a sort of watchman in charge of following the event bus in Home Assistant (and other things, like timers and REST endpoints).
Each trigger has a target condition which may depend upon one or more entities, attributes or other types of data collected by HA. Particularly for triggers depending on entity states, this is done using a dependency graph (trigger A depends on entity E, and so on and so forth). Ultimately, this lets the automation engine know exactly which events in the bus affect which triggers.
As events go through the bus, the watchman looks at the dependency graph. And then, using that graph, decides which triggers have to be recomputed due to the bus event it is processing, to see which triggers need to fire.
Because of the dependency graph, this computation happens very efficiently and very quickly. A great deal of why it is efficient is due to the dependency graph limiting what exactly needs to be evaluated based on what triggers are affected by a specific event. Another reason it is efficient is that when the automation engine recomputes each affected trigger, it never actually talks to an external subsystem to retrieve information — it’s always local data access (for evaluating most triggers, the engine really only needs to look at the specific event being processed).
In concrete terms: you have an automation that depends on a motion sensor in your bathroom, and another that depends on the water flow of your home. The triggers for your motion sensor automation only get evaluated when the motion sensor changes state. The triggers for the water flow automation only get evaluated when water flow changes. You could conceivably have 10,000 automations, but because only one of them gets evaluated, you only pay for the overhead of that one trigger, which is in the microseconds or nanoseconds range. The lookup from event to trigger and from trigger to automation is constant time, and so is the reevaluation of the trigger.
Admittedly, I don’t really have a full understanding of the engine because I haven’t read the source code of that part of HA in full. But you really have to marvel at what an amazing piece of technology it is.
In general, you don’t need to think about how efficient your automations or your triggers have to be. You just have to be careful not to demand that the automation engine (your trigger) is monitoring a ton of entities or monitoring very noisy entities.
