I have a Ceiling Light Fixture with 3x RGBWW(color temp control) (costco feit) tuya bulbs
I have replaced the switch wired to this fixture with a Shelly Plus Wall Dimmer
the Shelly Plus Wall Dimmer does not have a detached switch mode so I plan to cap the load output with a wire nut and wire the load cable from the fixture into the line wire nut.
(bypassing the switch so the smart bulbs have continuous power)
I created an automation with the trigger shelly switch on which sets the bulbs on and a second automation for shelly switch off turns the bulbs off
How do I make an automation for the shelly dimmer brightness to change the bulb brightness?
is there a different smart switch I need to buy to use as a “detached dimmer” to control smart bulb brightness?
