How do I expose servo/number to automation?
I have a d1 mini and I’ve got a simple push button that I’m trying to use to operate a servo. There will only be two positions on the servo. I can get the button to show up in automation but not the servo. What am I doing wrong?
esphome:
  friendly_name: Test Blast Gate
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key:
ota:
  - platform: esphome
    password:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Test-Blast-Gate Fallback Hotspot"
    password:
captive_portal:
binary_sensor:
  - platform: gpio
    pin:
      number: 2
      mode:
        input: true
        pullup: true
    name: "Simple Push Button"
output:
  - platform: esp8266_pwm
    pin: GPIO0
    frequency: 50 Hz
servo:
  output: pwm_output
As far as I know that is not possible.
There is no servo domain in HA.
What you could do is create two buttons or scripts in ESP-Home that you can trigger from HA and have the buttons/scripts set the position of the servo.
Or you need to pass a value from HA to ESP-Home that is then sent to the servo as the position.
I think this could work…
number:
    name: "Servo position"
    optimistic: true
    min_value: -100
    max_value: 100
    step: 1
    on_value:
      then:
        - servo.write:
          level: !lambda "return x/100;"
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO2
      mode: INPUT_PULLUP
      inverted: true
    filters:
      - delayed_on: 50ms
    on_press:
      then:
        - lambda: |-
            static bool state = false;
            state = !state;
            if (state) {
              id(blast_gate_servo).write(1.0);  // 180 degrees
            } else {
              id(blast_gate_servo).write(-1.0); // 0 degrees
I like this solution. I’ll try it out tonight. Thank you.
Not tested.
Map your servo angles though.
You’re welcome :wink:
This is what I did for continous servo’s. So as mentioned above, you’ll need to alter to fit your need i.e. the angles
time:
  - platform: homeassistant
# Timed Feeds
    on_time:
      - seconds: 0
        minutes: 00
        hours: 07
        then :
          - script.execute: trigger_servos
      - seconds: 0
        minutes: 30
        hours: 17
        then :
# Number
number:
    min_value: 0
    initial_value: 0.5
    max_value: 2
    step: 0.25
    optimistic: true
    mode: slider
    icon: mdi:rotate-right
# Servos
servo:
  - id: servo1
    output: output1
  - id: servo2
    output: output2
  - id: servo3
    output: output3
output:
  - platform: ledc
    pin: 16
    frequency: 50 Hz
  - platform: ledc
    pin: 17
    frequency: 50 Hz
  - platform: ledc
    pin: 18
    frequency: 50 Hz
# Switch
switch:
    optimistic: True
    icon: mdi:sync-off
    restore_mode: ALWAYS_OFF
# Buttons
binary_sensor:
  - platform: gpio
    pin:
      number: 4
      mode:
        input: true
        pullup: true
    on_press:
button:
    icon: mdi:cat
    on_press:
  - platform: restart
# Script
script:
  then:
    - if:
        condition:
          switch.is_off: disable_feed
        then:
          - servo.write:
              level: 100%
          - delay: !lambda 'return id(servo_control).state * 1000;'
          - servo.detach: servo1
          - servo.write:
              level: 100%
          - servo.detach: servo2
          - servo.write:
              level: 100%
          - servo.detach: servo3
    - script.stop: trigger_servos
# Spoilt Rotten Cats Live Here
