Hi!
I’m getting the following messages in my logs:
Logger: homeassistant.config
Source: config.py:508
First occurred: 16:55:07 (8 occurrences)
Last logged: 16:59:08
Invalid config for [automation]: must contain at least one of below, above.. Got OrderedDict([('default_config', {}), ('tts', [OrderedDict([('platform', 'google_translate')])]), ('automation', [OrderedDict([('id', 'badkamer_raam_lang_open'), ('alias', 'Badkamer - raam lang open'), ('trigger', [OrderedDict([('platform', 'numeric_state'), ('entity_id', 'sensor.badkamer_sensor_humidity'), ('below', 70), ('for', '00:10:00')])]), ('condition', [OrderedDict([('condition', 'state'), ('entity_id', 'binary_sensor.badkamer_raam'), ('state', 'on')])]), ('action', [OrderedDict([('ser.... (See /config/configuration.yaml, line 7).
Invalid config for [automation]: expected str for dictionary value @ data['condition'][0]['state']. Got None. (See /config/configuration.yaml, line 7).
“config/configuration.yaml” line 7 doesn’t exist. My configuration.yaml looks like this:
(line numbers added for clarification, not in the actual file)
/01/ # Configure a default setup of Home Assistant (frontend, api, etc)
/02/ default_config:
/03/
/04/ # Text to speech
/05/ tts:
/06/ - platform: google_translate
/07/
/08/ automation: !include_dir_merge_list automations/
/09/ binary_sensor: !include binary_sensor.yaml
/10/ device_tracker: !include device_tracker.yaml
so I’m guessing the issues are somewhere in the automations.
suggests an issue with a numeric_state
trigger or condition: I’ve checked all 65 of them, but haven’t found any missing an above or below.
so… any suggestions on how to find these issues?
Thanks!
