How do i fix http://homeassistant:8123/config/logs:0:0 Uncaught00 PM http://homeassistant:8123/config/logs:0:0 Uncaught
i got this error
Logger: frontend.js.latest.202308020
Source: components/system_log/__init__.py:270
First occurred: 12:56:08 PM (3 occurrences)
Last logged: 1:12:00 PM
when i look in full logs it shows this
2023-08-17 12:56:08.760 ERROR (MainThread) [frontend.js.latest.202308020] http://homeassistant:8123/config/logs:0:0 Uncaught
is there a configuration i need to change t loose this error?
my kitchen phone i use as a tablet for some buttons also giving the same error now too
First occurred: 4:56:03 PM (2 occurrences)
Last logged: 4:56:19 PM
http://192.168.20.12:8123/kitchen-phone/0:0:0 Uncaught
what does the error mean and is there a way i can fix it?
I think this is caused by the loss of connection to the browser/companion app when the device goes to sleep and the connection therefore times out.
oh ok so then its nothing to worry about… as i trying to get 0 errors but i dont think you really can can you… like have 0 errors 0 warnings
HA will throw a lot of warnings in every start because many integrations are not supported by the HA team.
Error will most likely be there too,because some integrations and some user defined values are not set up for the states under a start before the actual sensor values have been gathered. These values can be unknown, unavailable, weird extreme values or assumed.
ah ok ya i get sometimes warnings or errors cuz my internet isnt good enough so enviromental canada the connection goes down and i get errors… or i get some force pull update for Shelly devices saying i need to use colorIT whatever that is… but its set but i get those errors not sure what tehy for and my Tplink i get errors like lost connection… for the most part it works… i do find sometimes shutting off a light by a switch and node red is to turn off shelly lights are slow at times like 1 min delay other times its fast… not sure what s up with all that … but i do apreciate this program … back 20 yrs ago you had to pay 1000+ to have home automation
