How do I get a list of the installed Add-ons
I figured out to get a list of HACS installations (up-to-date or not), now I want the same for the Add-On’s but I have no idea how to do this…
Number HACS (up-to-date) : {{ states.update | selectattr('state', 'eq', 'off') |
        map(attribute='entity_id') | select('in',
          integration_entities('hacs'))| list | count }}
Number HACS (not up-to-date) : {{ states.update | selectattr('state', 'eq', 'on') |
integration_entities('hacs')) | list }}
I tried this, but this seems not to work :
Number ADD-ON (up-to-date) : {{ states.update | selectattr('state', 'eq', 'off') |
          integration_entities('Home Assistant Supervisor')) | list | count }}
          integration_entities('Home Assistant Supervisor')) | list }}
Found it : “Supervisor” instead of “Home Assistant Supervisor” :shushing_face:
And add this : | reject(‘match’, ‘update.home_assistant’)
I like this, but it shows items with skipped updates as ‘up-to-date’, correct?
This lists all update entities for Add-ons only.
{{ integration_entities('Supervisor')
  | select('match', 'update\.(?!home_assistant)')
  | list }}
On my system, it correctly lists 7 entities for 7 Add-ons.
One little problem with this one, the add-on “update.home_assistant_google_drive_backup_update”
Meanwhile I do it this way :
        {{ states.update
          | select('in', integration_entities('Supervisor'))
          | reject('match', 'update.home_assistant_core_update')
          | reject('match', 'update.home_assistant_supervisor_update')
          | reject('match', 'update.home_assistant_operating_system_update')
          | list | count }}
Ah! I don’t have that Add-on (or HA OS) so it wasn’t part of my testing sample. In that case, the regex pattern needs to be a bit more sophisticated.
  | select('match', 'update\.(?!home_assistant_(core|supervisor|operating_system))')
  | list | count }}
Or if you prefer a version with a simpler regex pattern.
  | select('match', 'update')
  | reject('search', '(core|supervisor|operating_system)')
  | list | count }}
EDIT
FWIW, you can probably reduce the string operating_system to just operating because it’s unlikely there are Add-ons with home_assistant_operating_some_other_name.
  | select('match', 'update\.(?!home_assistant_(core|supervisor|operating))')
  | list | count }}
  | reject('search', '(core|supervisor|operating)')
  | list | count }}
Dumb NOOB question - where does this code go? Can anyone provide an example? I’m a fast learner. TIA
