How do I get DHCP discovery to ignore one of my subnets?
I’m running Home Assistant OS on an Raspberry Pi. I have both interfaces enabled (wired and wireless) and on different subnets. All my IoT devices are on the wireless subnet.
Both interfaces are configured for “automatic” (DHCP) setup. I have changed the “Network adapter” setting to use the wlan0 interface.
How do I get DHCP discovery to stop finding devices on my wired subnet?
Remove the Ethernet cable feeding the subnet.
Change the IP address.
Add another AP or Router.
Take your pick.
I’ve dug into the source far enough to know that the homeassistant core is using aiodiscover, but I don’t even see a way to stop aiodiscover from not walking all the enabled interfaces.
Since aiodiscover is determining the network to scan based on the route to 10.255.255.255, it looks like I can set a route to the broadcast network via my wlan on the HA host.
