Working through an issue with an automation being run when Alarmo is triggered. I need to use a HA scripts, not Alarmo scripting because of needs to adjust speaker volume, etc. Stuff that Alarmo can’t do natively. So here’s my question.
I have 3 doors as part of the alarm, opening any one will create a trigger. If any of the doors open, it triggers a soft chime through the automation below. More of a signal that someone has come home than an actual alarm.
But I don’t know how to pass the variable to the script to announce “which” door is open. So the automation for the time being simply says “Front Door is Open”. Is there some way I could determine which door, and modify the automation accordingly? Automation is here. Really appreciate any advice:
alias: Alarm action in home mode called by Alarmo Triggered
sequence:
- service: siren.turn_on
tone: "30"
volume_level: 0.2
device_id: ef9fd809872118c7964c45e54bdb7479
entity_id: siren.indoor_siren_6_3
- service: media_player.volume_set
data_template:
entity_id:
- media_player.google_speaker_group_outdoor
volume_level: 0.5
data_template:
entity_id:
- media_player.google_speaker_indoor_group
volume_level: 0.3
- service: tts.speak
cache: true
media_player_entity_id:
message: The front door is opening. The front door is opening.
entity_id: tts.piper
- service: notify.Both_Phones
message: Front Door was opened
title: Front Door was opened
ttl: 0
priority: high
mode: restart
