How do I install previous version?
Hello.
My Z-Wave integration stopped working after an update tonight. How can I install the previous version? Should I install a backup file? Or is there something else I can do?
Restore a backup that contains the previous version (usually the add-on specifically).
You can also look at the add-on logs first and see why it’s failing.
Indeed, use the backup
Hi.
Thanks for your comments. It feels like you’re not completely alone when you have problems.
Anyway, I think a reboot solved it, because now it seems to be working again.
Thanks anyway.
Did you update zwave?
Many times if you update HA you also MUST update zwave integration. Failure to do so will cause the problem you have.
Could verify this for you if you tell your current working HA version.
