How do I make trigger URL API calls via Home Assistant?
I am fairly new to Home Assistant and I wish to be able to make URL API calls via either buttons on my Home Assistant home page OR trigger these URL API calls via an automation.
For example, if I wish to detach a Shelly relay, I may wish to call:
http://192.168.1.x/rpc/Switch.SetConfig?id=0&config={%22in_mode%22:%22detached%22}
And then if I wish to set it back to active, I may wish to call:
http://192.168.1.x/rpc/Switch.SetConfig?id=0&config={%22in_mode%22:%22follow%22}
I want to be able to trigger these via a toggle switch on my home screen or via an automation.
What is the best way to achieve that?
Rest command makes the url available to be scripted. Then you write a a scriptthat performs your get/put/post/delete
if you want to follow this path, it is a valid one.
If you want an easier one, you can try Shelly integration. This integration will create switch entities automatically for you and will handle all commands too.
Thanks for your reply. I am using the Shelly integration already for normal light function, but the integration module does not currently offer a way to change the switch mode - hence why I am looking at making a direct API call.
Thanks. This ‘Restful Command’ looks perfect. I will take a look into that.
Solved it. For others reading this post in the future, I was able to simply edit my configuration.yaml file to define a new switch.
Remember to restart Home Assistant after adding this:
switch:
  - platform: rest
    resource: http://192.168.100/rpc
    method: post
    headers:
      Content-Type: application/json
    body_on: '{"id":1,"method":"Switch.SetConfig","params":{"id":0,"config":{"in_mode":"follow""initial_state":"match_input"}}}'
    body_off: '{"id":1,"method":"Switch.SetConfig","params":{"id":0,"config":{"in_mode":"detached","initial_state":"off"}}}'
    state_resource: http://192.168.1.100/rpc/Switch.GetConfig?id=0
    is_on_template: "{{ value_json['in_mode'] == 'follow' }}"
