Note: this was initially posted in Third Party Addons with a different title. I moved it as it seemed to have wider relevance.
I use the EmonCMS integration to bring in a variety of home sensors. The physical sensors are OK and emonCMS is displaying them correctly, however the integration of one feed has changed without any manual intervention.
The sensors have been created using the following config
- platform: emoncms
api_key: !secret opencms_api_key
url: http://mycms.foo.bar
unit_of_measurement: "°C"
sensor_names:
22: "Bedroom1 Temperature"
24: "Livingroom Temperature"
25: "External Temperature"
33: "Bedroom2 Temperature"
37: "Shack Temperature"
The mis-performing one is feed 25 “External Temperature”
When added initially, sensor.external_temperature
was created as expected (the same for the others).
At some point in the last couple of days sensor.external_temperature
became unavailable and a whole lot of automations broke. When I explored, I found a new sensor sensor.external_temperature_2
had been created and is now carrying feed 25.
Question: - How do I revert the configuration so the feed is back on sensor.external_temperature
without losing the historical data?
