How do I remove an integration that has not fully integrated?
I made a mistake when I wanted to integrate Google Sheets.
I thought I could just close it and remove the integration, but the integration does not show up in the integrations list.
If I try and add Sheets again it just tries to validate the previous wrong configuration.
I tried to restart in the hope it would clear integrations stuck in between but it didn’t.
So now I have an integration that HA wants to validate in order to be able to remove, but Google says it’s incorrect and won’t validate it.
What to do? Is it the .storage file?
Same problem here.
Have not tried this integration myself, but have you tried opening the credentials menu in the top right menu from integrations to see if there is a bad google credential there?
This worked!
I had no idea there was a menu up there.
