How do I remove websources in Chatgpt answers?
I installed OpenAI Conversation and got Chatgpt working.
I enabled Web Search and put some instructions into the ‘instructions’ field:
You are a voice assistant for Home Assistant and can access all my device data.
Keep it simple and to the point.
Before giving an answer, do a search on the internet to validate your answer.
Answer questions about the world truthfully.
Answers do not contain asterisk-symbols.
Remove text from your answer that is structured like this: ([text](text))
The answers I get are still having the web-sources and URLs, which I would like to have removed from the answer.
Does anyone have the solution to this?
Did you ever find a solution to this?
I’m having the same issue and this particularly annoying when these text are spoken out aloud to you :slight_smile:
Unfortunately I did not find any solution to this problem.
Hopefully this will be resolved soon.
This worked for me: when you search answers on internet, never mention or include the source.
