How do I restore a snapshot without web interface
I am using Hassio Home Assistant in Ubuntu via Docker
Restored a snapshot to a version older than the Home Assistant version.
The problem now is that the web interface no longer starts.
Have been trying to fix this for a long time, but to no avail.
Can I restore a snapshot via the shell? See several options on the internet, but those are not workable commands for me.
Found the location where a recent snapshot is, but how can I restore it?
Have you tried the ha command in the shell?
Yes I tried, but then I get the following message:
ha: command not found
If you check which docker containers are running is there a hassio_cli container running? You need that to have the ha command available.
I see this one that looks like it.
91f114b4732a homeassistant/amd64-hassio-cli:25 “/init /bin/bash -c ⦔ 37 minutes ago Up 37 minutes hassio_cli
I solved the problem by reinstalling Home Assistant Hass.io and then put file in the backup folder and restored snapshot.
