How do I scedule time in node red using input to the node?
I would just like to know if it will be possible to set the times trough a UI/inject node/input as I have another user that I dont want to give access to the back end but I would want them to be able to change the timing scedule.
I am now using a home assistant itself to send a input when the time is reached but I would like to do it all in node red does anyone know of a schedule node which can be change based on input send by for example a input node?
Thanks.
Create an input date time in HA and set it to a time node in NR.
