How do I specify dimmer brightness in Alexa Cloud?
My Alexa cloud connection works great for “Turn On Kitchen Lights” but how do I say “Turn On Kitchen Lights 50%”?
Specifically the problem is that “Turn On Kitchen Lights” will turn on the lights with the brightness set to the prior level. So if the prior level was only 20%, then that’s the brightest you’ll get with voice.
Alexa has smart home skills for setting brightness:
https://developer.amazon.com/docs/device-apis/alexa-brightnesscontroller.html
But none of these directives seem to work with Home Assistant Cloud.
Did you ever figure out a solution for this?
