How do I use a 36400-MP relay with ESP home and Home Assistant?
I cannot seem to get the relay to work with the esp8266 I am using. This is the current code I have:
esphome:
esphome:
  friendly_name: gate-controls-8266
esp8266:
  board: esp01_1m
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "REMOVED"
ota:
  password: "REMOVED"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "REMOVED"
    password: "REMOVED"
uart:
  baud_rate: 9600
  tx_pin: 2
switch:
  - platform: uart
    name: "Gate relay on"
    data: [0xA0, 0x01, 0x01, 0xA2]
  - platform: uart
    name: "Gate relay off"
    data: [0xA0, 0x01, 0x00, 0xA1]
binary_sensor:
  - platform: gpio
    pin: GPIO2
    device_class: door
    filters:
      - invert:
I have tried to use serial communication and it has not worked. No output from the relay, tried multiple different relays and ESP-8266s. Here is the datasheet for the 36400-MP (https://www.mpja.com/download/36400mpdata.pdf). Any help is appreciated. (EDIT: Yes, I have looked at previous forum posts about the issue!) (EDIT 2: Tried 115200 Baud rate, still not working)
