I’m using hassio and I want to be able to use my yeelight lamp and broadlink remote-control in my home network. these integrations require IP in the config.yaml.
The problems:
- No static IP- I don’t have access to my router configuration and therefore can’t assign static IP to these devices.
- No hostname - my devices don’t have a hostname.
I would really appreciate help
Yeelight doesn’t require YAML configuration, it can be setup through the UI and automatically find yoir devices. The same goes for Broadlink. Are your devices not showing up there?
Get a new router xD
yes, they are showing up, but I’m not the administrator and I don’t want the integration to break when they’ll get a new IP address.
What do you mean with this?
I don’t think it will break when the IP is changed, but you’d need to test this. I assume you only have this problem when you define an IP in configuration.yaml.
If it breaks when the IP is changed, then I think you are out of luck when you are not able to set static IPs or hostnames.
The network is a public dormitories LAN and I don’t have access to the router’s configuration.
I’ll check if it breaks the integration and let you know… Any way, no solution in case it stops working? Thanks!
