How do we use restore_state for input_select and input_slider?
It was added in 0.39, but I don’t know how to configure it.
To my understanding this is automatic. It will grab the latest data from the recorder component and set it to that state.
I just tried moving an input_slider. Restarted HA and it was back at zero.
FYI . According to the blog its supported for input_select and input_boolean. input_slider wasn’t mentioned.
Yup. I also think (not checked) that if you have an initial value for an input_boolean, that will override the state restore
So even if I have initial state setup to the input boolean, it will restore the previous state?
and what if I DO NOT want state to be restored on a particular input Boolean?
@Amir974 I think that’s when you use "initial: " as shown here.
I am using Initial at the moment…
My question is how does initial work with state preservation?
  • Does initial override state preservation or do they work together?
  • What if I want to set initial for a Boolean switch for the first run but from that point on rely on state preservation across restarts? can I do that ?
I would assume you can either have one or the other. Initial will set it on reboot and if you don’t have it, it will use the last saved state.
