How do you show Covers in Lovelace UI?
Any and all ideas are welcome !
Hiding the slider by default because I would hit it by accident. A lot.
Nice @Emphyrio, I just saw custom:slider-entity-row by @thomasloven which is very nice
What are you using to achieve this functionality ?
What you said :slight_smile: A slider in a conditional card. Also, I use a cover template. That way I can set an input_boolean ‘manually controlled’, that indicates the automation for automatic control should keep its hands off for a while.
Unfortunately I have not yet understood which card was used here. How did you manage the controls? I would also like to use this card to control my awning.
This is not one card. They are simply entity, slider and buttons in horizontal and vertical stacks.
Could you post a copy of the code you used for this?
I’m sorry, but I replaced this code. If I would do this again, I would look at putting the slider in a popup by browser_mod.
@Emphyrio How did you implement your input_boolean manual controlled template? I have a bunch of ‘dumb’ Tuya curtain switches are not aware about the motor positions (neither by a fake time position…) so I’m seeking for something else that allow me to simulate the positions by using operation time (of the curtain motor/switch) … Thanks :slightly_smiling_face:
Can’t help you there. I use Z-wave, it is aware of the position.
