Just understand there are limitations to this apparently that I did not see when mentioning this in the release thread. So this is likely not a permanent solution unless you build it yourself.
Thanks for the clarification, when I did a search on this it says almost the opposite of what you said in the release thread.
In Home Assistant, users cannot typically “choose” a specific version of the core frontend to run independently of the server’s version. Instead, the Home Assistant Frontend integration serves the version bundled with your current Home Assistant Core installation.
