It installs and runs, though I’m having DNS issues that others have reported with LE and DuckDns. How can I, from the Ubuntu command line gain access to the Hassio shell? I believe there is a docker command, but I can’t figure out how to get in.
docker exec -it hass /bin/bash
that’s provided your docker is called hass, not sure what the name is for hass.io
you should be able to get the name using docker ps -a
@lolouk44 forgive me for being dense, but why do ups have two of them? Which one is correct?
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
94e4bc034e3e homeassistant/qemux86-64-homeassistant "/bin/entry.sh pytho…" 5 minutes ago Up 5 minutes homeassistant
17c13e9a9269 homeassistant/amd64-hassio-supervisor "python3 -m hassio" 6 minutes ago Up 6 minutes hassio_supervisor
I’m sorry I don’t know the answer for this one. As hass.io is an all in one solution, I can only think the 2nd container is for admin purposes (hence the name amd64-hassio-supervisor?), like maybe check for updates and install them?
based on this, I’m guessing your are running Ubuntu Bionic.
If so, this is a known issue with Docker & Ubuntu Bionic, which I hope someone is going to resolve, since the internet is full of it.
A quick workaround, run this on your Host machine (Ubuntu) as root user:
