Regarding the schematic, can someone explain how this works? If the Shellys state is off , O (blue) should have no power. How can the switches work then?
The source is a german YouTube Video and he shows that its working.
As it has no neutral so there is a leak towards neutral wire on the output load to ensure power to the relay, so it might work but not according to the documentation.
I found none in the official Shelly docs where I can solve the problem that the live wire is only available at the first switch and the lamp wire is only available at the last switch which is typical for older german Kreuzschaltungen.
Between the first and last switch are only two wires available and all official Shelly solution’s would require three.
I had 2 instances in my house that are exactly like the one presented in this diagram ( I used exactly the same picture ). Both working perfectly reliable since ~3 years, no issues. Indeed the trickery of this setup is related to not having neutral available (so bypass required if power leak is too small) and actual load source and receiver being connected to different switches.
If you have 3 switches setup, it might not work properly, since Shelly 1L works here with both switches configured as edge switches, eg. 1L toggle light based on each of switches toggle, which might mean it is unrelated to their combined state - both might be on, off or in on/off combinations. So in fact you are using here existing wiring to create setup with 2 independent switches rather, that using it in real 2-way or 3-way setup that on any switch toggle also toggles power delivery.
the comments in the original source suggest that the same circuit doesnt work with the shelly 1L gen3 anymore, so i have to look for other solutions. Replacing all switches with toggles would work with existing wiring.
Im still wondering, since other diagrams for the shelly 1l gen3 suggest for example connecting S1 to the switches input and the switch output to Sx, is live internally connected to S1 and S2?
[quote=“morkar, post:5, topic:962382”]
[/quote], I am not german speaking so I might have not understand it correctly but isn’t it usually a three switch configuration? Two two way rocker and one invertor?
If you are in this situation it might need a different wiring then the one I will suggest here below.
If I understood correctly your wiring you need to add a wire for the shelly output to lamp.
If you want to detect from HA what switch has caused the triggering of the ON/OFF you need to wire one switch to S1 the other to S2.
At this point if you are unsure and you are not an electrician I would ask to some professional.
About the voltage on SX I don’t know but for sure there is some voltage going around.
I don’t have a Shelly 1L yet. I encountered the problem after trying to integrate my second floor lighting. If there is a solution I will get a Shelly 1L gen3 since it’s the current version and it’s the only Shelly working without neutral at the switch.
