How does zwave-js add Custom information in Device Panel
I see that zwave_js is able to place additional information in the device panel. I’ve also browsed it’s source code and don’t see how it is done. I have an integration that I’d like to add information to this panel - how is this done?
The ha-config-device-page custom element has special code to handle zwave_js devices, and this is the code that renders the Z-Wave Info for the device. The data is obtained via the websocket API.
Thanks. Looks like the simple way. Be good to have it extensible via an attribute dict. Maybe I’ll find some time…
The equipment in the integration I manage has lots of useful stuff - equipment type, model number, serial #, capacity, # of stages, control sw version,…
I suppose I could add a single sensor entity with a bunch of attributes but having some of that stuff which is static in the device page would be useful…anyways….
                                    "id": 1,
                                    "feature": {
                                        "name": "Equipment Type Name",
                                        "format": "nts",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "HeatPump"
                                        "fid": 15,
                                        "unit": ""
                                    "id": 2,
                                    "feature": {
                                        "name": "Unit Model Number",
                                        "format": "nts",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "EIM - Heat Pump"
                                        "fid": 6,
                                        "unit": ""
                                    "id": 3,
                                    "feature": {
                                        "name": "Unit Serial Number",
                                        "format": "nts",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "1710-018423"
                                        "fid": 7,
                                        "unit": ""
                                    "id": 4,
                                    "feature": {
                                        "name": "Unit Nominal Capacity",
                                        "format": "u16q4",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "42"
                                        "fid": 5,
                                        "unit": "kBTU"
                                    "id": 5,
                                    "feature": {
                                        "name": "Number of Heating Stages",
                                        "format": "uint8",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "1"
                                        "fid": 1,
                                        "unit": ""
                                    "id": 6,
                                    "feature": {
                                        "name": "Number of Cooling Stages",
                                        "format": "uint8",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "1"
                                        "fid": 2,
                                        "unit": ""
                                    "id": 7,
                                    "feature": {
                                        "name": "Heating Capacity by Stage",
                                        "format": "0p5",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "100"
                                        "fid": 3,
                                        "unit": "%"
                                    "id": 8,
                                    "feature": {
                                        "name": "Cooling Capacity by Stage",
                                        "format": "0p5",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "100"
                                        "fid": 4,
                                        "unit": "%"
                                    "id": 9,
                                    "feature": {
                                        "name": "Control Software Revision",
                                        "format": "nts",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "1.10"
                                        "fid": 11,
                                        "unit": ""
                                    "id": 10,
                                    "feature": {
                                        "name": "Control Model Number",
                                        "format": "nts",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "10T50"
                                        "fid": 8,
                                        "unit": ""
                                    "id": 11,
                                    "feature": {
                                        "name": "Control Serial Number",
                                        "format": "nts",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                        "fid": 9,
                                        "unit": ""
                                    "id": 12,
                                    "feature": {
                                        "name": "Control Hardware Revision",
                                        "format": "nts",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "B01"
                                        "fid": 10,
                                        "unit": ""
                                    "id": 13,
                                    "feature": {
                                        "name": "Outdoor Air Temp Sensor",
                                        "format": "tid",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "29"
                                        "fid": 34,
                                        "unit": ""
                                    "id": 14,
                                    "feature": {
                                        "name": "Pre Coil Discharge Air Temp Sensor",
                                        "format": "tid",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "30"
                                        "fid": 21,
                                        "unit": ""
                                    "id": 15,
                                    "feature": {
                                        "name": "Protocol Revision Number",
                                        "format": "uint8",
                                        "szValues": 2,
                                        "values": [
                                                "id": 0,
                                                "value": "1"
                                                "id": 1,
                                                "value": "6"
                                        "fid": 12,
                                        "unit": ""
                                    "id": 16,
                                    "feature": {
                                        "name": "Device Product Level",
                                        "format": "uint8",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "190"
                                        "fid": 13,
                                        "unit": ""
                                    "id": 17,
                                    "feature": {
                                        "name": "24VAC Average Power Consumption",
                                        "format": "u16q8",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "0"
                                        "fid": 17,
                                        "unit": "W"
                                    "id": 18,
                                    "feature": {
                                        "name": "24VAC Peak Power Consumption",
                                        "format": "u16q8",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "0"
                                        "fid": 16,
                                        "unit": "W"
                                    "id": 19,
                                    "feature": {
                                        "name": "Line Voltage Avg. Power Consumption",
                                        "format": "u16q4",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "0"
                                        "fid": 19,
                                        "unit": "W"
                                    "id": 20,
                                    "feature": {
                                        "name": "Line Voltage Peak Power Consumption",
                                        "format": "u16q4",
                                        "szValues": 1,
                                        "values": [
                                                "id": 0,
                                                "value": "0"
