Hello Home Assistant fans,
I am a fresh HA user and for the past month I have been learning and tinkering. At first I compared Zigbee to Matter/Thread and I have made a decision that Matter and Thread, overall, are much better aligned with my smart home expectations. They never require internet or cloud or any 3rd party apps. They work after their manufacturer bankrupts, and so on. With this needed introduction I wish to discuss my choices and I ask for your opinion.
At first I purchased Sonoff M5 switch that is Matter over WiFi. This one requires a custom phone app to setup so it should have been eliminated from my choices, but I was so eager to install something that I told my self okay, let’s try it. It was the only switch that I could purchase and have in my hands that same day. My opinion after two weeks with it: it is less than ideal.
After a research I came up with Aqara H2 EU. I have already read many negative reviews, in the light of its Matter integration, but alas — it still felt like the best choice, until I find better. Today it has arrived and I did some tests:
First I tried with IKEA Kajplats bulb without the neutral wire and it seemed to work fine, except no Thread Routing and no power monitoring. Then I connected the neutral to get the remaining functionality:
- when I press top buttons they control relays directly and report the on/off status to HA, very similar to how Sonoff behaves
- when I press bottom buttons I get single press events (but twice in a row) in HA, so I can use these for various automation and to toggle my IKEA smart lights. why it sends each button press twice in a row, that remains a mistery. TBH it feels like a firmware bug
- while it does not expose double press and long press events to HA, it does expose the status of button pressed or not: while holding the button the value in HA is 1, when let go it is 0. So I have uses THAT functionality to BOTH toggle my lights AND to dim them: if button was held for less than 300ms then toggle light, but if the button is held for longer than 300ms then dim the light every 150ms by steps of brightness value of 5.
- since this switch is installed in my bathroom, at the moment, I have used the top buttons for the ventilation fan and for the mirror light so all four buttons are doing something
What does not work is tiny LED lights on the bottom switches. They are not exposed to HA so I have no way to fire them up. The upper ones do work because they are coupled locally with their relays. So when I turn on my mirror light in the bathroom then its tiny blue LED light lights up, but when I turn on the main bathroom IKEA bulb then I have no LED feedback on the Aqara switch. Either having all indicators working or having none of them working would be preferred to this mismatch hehe. I am aware that this is the limitation of the firmware in Matter mode, but it would be nice to see Aqara give more Matter love (mater means mother in my language, btw) to this switch.
I ask for your opinion on this switch and which one else might you recommend to me to be a better choice when it comes to Matter-over-Thread? Please speak from experience because specifications are one thing but using the device is another.
My end goal is to purchase 7 switches of the same type/kind for my apartment after I am fully satisfied with the test run. For now Aqara is a better device than WiFi Sonoff, for sure, but it feels “unfinished” from the Matter side of things.
Thank you for your opinion.
